Old 06-02-2010, 07:05   #1 (permalink)
Member: 340567
Unhappy HELP : 5130-c security test failed
log:
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.95 03-02-10 RM-495 (c) Nokia
Imei plain: 35523203585710-1
Product Code: 0578115
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355232035857101
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
try to write pm1,309 from another phone :
when do super sd auth:
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 07.95 03-02-10 RM-495 (c) Nokia
Using cached productData[21400219FC157E5601452460DEE6B4109F9FDF5D] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
have been try severall times.......
please help me.....
Old 06-02-2010, 07:25   #2 (permalink)
.::VENUGOPAL::.'s Avatar
Member: 1230663
Sonork: 100.1593487
Thanks Meter: 174
http://forum.gsmhosting.com/vbb/f550...cking-1013674/
Old 06-02-2010, 07:57   #3 (permalink)
Member: 340567
Originally Posted by VM_SODHA View Post
bro try
write good pm file with ppm autho
yes i have try it...but when i do ppm auth.....
SUPERDONGLE authorized !
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
Phone authenticated to SUPERDONGLE already. write pm from good another 5130-c
result :
Product Code: 0571584
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
Done.
same answer.......
Old 06-02-2010, 08:01   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
need to write pm field 1+309 by pmm auth.
Old 06-02-2010, 08:09   #5 (permalink)
faisal.u7's Avatar
Member: 1028120
Sonork: 100.1607216
Thanks Meter: 90
only write rpl pm 1 to 309 not available rpl pm so read ok pm and load mxkey then unmark all pm cheks only 1 and 309 mark and write problem solve ok bro
Old 06-02-2010, 09:18   #6 (permalink)
akashub's Avatar
Member: 750001
Sonork: 100.1641021
Thanks Meter: 1,269
here is the solution for 5130-XM SECURITY_TEST failed!
5130-XM CS removed sucessfully by MX-KEY
Old 06-02-2010, 10:01   #7 (permalink)
Member: 340567
ok all...now that phone is normal again...
i do reset npc
write another pm (full)
than write rpl back
do super sd auth (if i do pmm auth it still not work )
and write full pm again from another phone then reset all
and this is the end.....
Language Pack:
- not available.
SIMLOCK_TEST passed
SECURITY_TEST passed
Counter: 0/3, 0/10
thanks for all...... trade close......
Old 06-02-2010, 10:46   #8 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 392
bad phones ack means you must press SUPER SD AUTH button instead of pmm auth
br
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Winlock 1.10 - Help rdmfs Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-1999 08:21
Page generated in 0.19736 seconds with 9 queries
