Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 06-30-2010, 20:34   #1 (permalink)
Member: 1012165
help 5130c contact service i have backup rpl and pm
help i have a nokia 5130c after flashing it started showing contact service
i have the backup rpl and pm from jaf auto backup i tried writing the rpl with jaf
it was successfull but pm was not successfull this did not change any thing
i copied the pm and rpl to mxkey i tried restoring the imei on mxkey it showed successful but no change
pls help me i am in a mess what do i do
Powering the phone...
Writing PM...
Field: 308, Record: 1, Len: 8192 -> Error: Need SX4 auth..
Done!
Scanning RPL file...
NPC DATA OK...
VARIANT DATA NOT FOUND...
CCC DATA OK...
HWC DATA OK...
NPC APE DATA NOT FOUND...
VARIANT APE DATA NOT FOUND...
CCC APE DATA NOT FOUND...
HWC APE DATA NOT FOUND...
SIMLOCK DATA NOT FOUND...
SIMLOCK KEY DATA NOT FOUND...
SUPERDONGLE KEY DATA NOT FOUND...
CMLA KEY DATA NOT FOUND...
WMDRM PD DATA NOT FOUND...
Connecting to phone...
FAST PHONE detected!
CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
Loader version: 01.1E.00 -> Revision: 0000
Patching CMT boot step1...
Patching CMT boot step2...
Patching CMT boot step3...
CMT Boot Ready
CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
Loader version: 01.21.01 -> Revision: 0000
Patching CMT loader step1...
Patching CMT loader step3...
CMT Loader Ready
Writing NPC DATA...
Writing CCC DATA...
Writing HWC DATA...
Restarting phone...
Done!
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1BB0010FE54F7F56D7DD19DE962831CE61BC1D42
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Original Imei: 35524603802004
Original Product code: 0572176
Bluetooth ID: 0025D0DD1020
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.90 23-09-09 RM-495 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0572176
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei plain is invalid !!!
SIMLOCK_DATA corrupted!
The Following 2 Users Say Thank You to tonywireless For This Useful Post:
Old 06-30-2010, 23:27   #2 (permalink)
karurosu316's Avatar
Member: 452143
Writing PM...
Done!
NPC DATA OK...
CCC DATA OK...
HWC DATA OK...
CMT Boot Ready
CMT Loader Ready
Writing NPC DATA...
Writing CCC DATA...
Writing HWC DATA...
Restarting phone...
Done!
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
Repair SD + PM auth + Pm + Pm (1 - 309) + Factory Setiings = Full 5130
The Following User Says Thank You to karurosu316 For This Useful Post:
Old 07-01-2010, 03:13   #3 (permalink)
Member: 1028010
The Following User Says Thank You to kekexili For This Useful Post:
Old 07-01-2010, 03:38   #4 (permalink)
Member: 587083
thats our problem but no more sulution
no sulution because our phone is sl3
The Following User Says Thank You to ner21 For This Useful Post:
Old 07-01-2010, 04:44   #5 (permalink)
Member: 1012165
i think there should be a solution since i have backup rpl and pm ?
The Following User Says Thank You to tonywireless For This Useful Post:
Old 07-01-2010, 04:48   #6 (permalink)
Member: 1012165
when i try to repair super dongle this is what it tells me
Product: V 07.90 23-09-09 RM-495 (c) Nokia
Using cached productData[1BB0010FE54F7F56D7DD19DE962831CE61BC1D42] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
SERVER: IMEI number null, empty or invalid (12345610654321?)!
any help from any body pls?
Old 07-01-2010, 05:01   #7 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
if there is back up rpl before contact service
you can solved this
other wise no solution
The Following User Says Thank You to rakesh15 For This Useful Post:
Old 07-01-2010, 05:02   #8 (permalink)
Member: 1003445
sir your logs shows SIMLOCK_DATA corrupted,
5130c is an sl3 phone,
so sad to say its not yet supported
The Following User Says Thank You to white_beard For This Useful Post:
Old 07-01-2010, 05:11   #9 (permalink)
Member: 464289
first restore imei and do next step repair.
exp : repair SD........ bla-bla-bla
remember : SL3 simlock can't restorable
maybe you can restore simlock using this trick
restore simlock from backup JAF. but first U must change the format PM to RPL simlock..
hope will help U..
CMIIW.
SCTEAM
The Following User Says Thank You to kuburan_cell For This Useful Post:
Old 07-01-2010, 14:08   #10 (permalink)
Member: 1012165
hi all pls can u pls tell me how to restore with the back up i got from jaf auto backup before the 5130c had contact service still waiting
Old 07-01-2010, 14:37   #11 (permalink)
Crazy Poster
Member: 756379
i have 1 nokia 5130 phone that phone sho coantservice pls help me sl data is currepted
The Following User Says Thank You to mrm.nasir For This Useful Post:
Old 07-08-2010, 17:30   #12 (permalink)
n2roy's Avatar
Member: 1175794
Till now no solution..
because nokia 5130c is sl3..
sl3 unlocking is no not possible (till now).
The Following User Says Thank You to n2roy For This Useful Post:
Old 07-09-2010, 06:06   #13 (permalink)
Member: 334244
Cool
brother this is sl 3 phone mx key not released ...waiting plz
Old 07-09-2010, 06:10   #14 (permalink)
Member: 784847
Writing PM...
Done!
NPC DATA OK...
CCC DATA OK...
HWC DATA OK...
CMT Boot Ready
CMT Loader Ready
Writing NPC DATA...
Writing CCC DATA...
Writing HWC DATA...
Restarting phone...
Done!
RAP Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
bro plz wait for sl3 unlocking............
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
HELP!!! BACKGROUND SCREEN LOGO Michael Go Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-25-2011 23:56
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-25-2009 16:29
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.84619 seconds with 11 queries
