06-05-2010, 06:38 | #1 (permalink) |
No Life Poster Join Date: Apr 2009
Member: 1012165 Status: Offline Thanks Meter: 116 | help 6500c contact service after unlocking after restoring backup on mx-key with restore sim lock back up it still shows contact service i also used imei rebuild to restore simlock still contact service what do i do to restore it backto its former state or to make it properly unlocked? Phone Type: RM-265 (Nokia 6500c) SW Version: V 05.81 06-02-08 RM-265 (c) Nokia Imei plain: 353099027271.... Product Code: 0556153 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35309902727.... Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF log after restoring backup Phone Type: RM-265 (Nokia 6500c) SW Version: V 05.81 06-02-08 RM-265 (c) Nokia Imei plain: 353099027271.... Product Code: 0556153 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 35309902727.... Version: SIMLOCK SERVER Provider: Virgin, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343000000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23430F, DATA=23430F |
06-05-2010, 07:15 | #3 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | thanks for ur reply but when i try to wrte pm this is what i get Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (182 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 5.328 s when i click super sd authorization first before writing pm i still get this so what do i do Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010) Product: V 05.81 06-02-08 RM-265 (c) Nokia Using cached productData[0D3000021E964F507CD70C9C740B35D3E5D732EA] ... Authenticating to SUPERDONGLE using security server ... Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted ! Wrong response to SD verify request Writing PM from Node ... Section: 1 Warning: failed to write 1 - 0 (114 bytes) Warning: failed to write 1 - 2 (98 bytes) Warning: failed to write 1 - 4 (110 bytes) Warning: failed to write 1 - 6 (98 bytes) Warning: failed to write 1 - 8 (110 bytes) Warning: failed to write 1 - 13 (98 bytes) Warning: failed to write 1 - 16 (98 bytes) Warning: failed to write 1 - 18 (98 bytes) Warning: failed to write 1 - 20 (98 bytes) Warning: failed to write 1 - 22 (16 bytes) Warning: failed to write 1 - 23 (4 bytes) Warning: failed to write 1 - 24 (84 bytes) Warning: failed to write 1 - 25 (4 bytes) Warning: failed to write 1 - 26 (110 bytes) Warning: failed to write 1 - 28 (98 bytes) Warning: failed to write 1 - 29 (10 bytes) Warning: failed to write 1 - 31 (98 bytes) Warning: failed to write 1 - 33 (36 bytes) Warning: failed to write 1 - 34 (80 bytes) Warning: failed to write 1 - 40 (16 bytes) Warning: failed to write 1 - 41 (182 bytes) Warning: failed to write 1 - 42 (4 bytes) Warning: failed to write 1 - 43 (36 bytes) Warning: failed to write 1 - 44 (182 bytes) Section: 309 Warning: failed to write 309 - 0 (4 bytes) Warning: failed to write 309 - 1 (2 bytes) Warning: failed to write 309 - 2 (12 bytes) Warning: failed to write 309 - 4 (12 bytes) Warning: failed to write 309 - 5 (12 bytes) Warning: failed to write 309 - 7 (12 bytes) Warning: failed to write 309 - 8 (12 bytes) Warning: failed to write 309 - 17 (12 bytes) Completed in 5.328 s |
06-05-2010, 07:25 | #5 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: india Age: 36
Member: 690456 Status: Offline Sonork: 1587650 Thanks Meter: 117 | Quote:
plz unlock that set agine zulay solved ur problem 100% | |
06-05-2010, 07:30 | #6 (permalink) | |
Freak Poster Join Date: Jun 2010 Location: Underground
Member: 1317565 Status: Offline Thanks Meter: 61 | Quote:
06-05-2010, 14:49 | #7 (permalink) |
No Life Poster Join Date: Feb 2006 Location: syria Age: 46
Member: 231153 Status: Offline Thanks Meter: 313 | Mxkey>serves>imei&securty>imei rebuild >repair sd go to pm load pm then click super sd auth and writ pm full factory |
The Following User Says Thank You to alasmmar For This Useful Post: |
