Old 06-29-2010, 15:14   #1 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
3110c update simlock error need soluation
3110 FLASHING LOG.......
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 14B002105E9B7B56C6DEA975FE77BCB75F011CA6
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
TransmissionMode: DDR&TX2
Original Imei: 35683302886672
Original Product code: 0550573
Bluetooth ID: 0022FDF86C8F
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35683302886672-5
Product Code: 0550573
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
Imei net: 356833028866725
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
PLZ HELP ME URGENT
Old 06-29-2010, 15:17   #2 (permalink)
shashankmobile's Avatar
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
Repair sd > Update Simlock > write pm 1 or 309 area by pm auth.
Simple.
Br.
Shashank
Old 06-29-2010, 15:25   #3 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
REPAIER SD...........LOG
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Using cached productData[14B002105E9B7B56C6DEA975FE77BCB75F011CA6] ...
Calculating SUPERDONGLE using security server ...
SERVER->Served by MXKEY - BLADE X at host1, agent version 1.1 revision 0.1
[CR2]BB5 remaining credit: 18
Completed in 2.844 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_356833028866725_SD.RPL"
Updating SUPERDONGLE_KEY ...OK
REPAIER SIMLOCK....LOG
Counter: 0/3, 0/10
Calculating SIMLOCK using security server ...
[CR2]BB5 remaining credit: 17
Completed in 3.781 s
RPL saved to "C:\mobileEx\3.4\data\backup\BB5_RM-237_356833028866725_SIM.RPL"
Updating SIMLOCK...error 0x1
Reading Simlock info ...
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
writem pm....
Section: 1
- Key: 0, size 114 bytes written.
- Key: 2, size 98 bytes written.
- Key: 4, size 110 bytes written.
- Key: 6, size 98 bytes written.
- Key: 8, size 110 bytes written.
- Key: 13, size 98 bytes written.
- Key: 16, size 86 bytes written.
- Key: 18, size 86 bytes written.
- Key: 20, size 86 bytes written.
- Key: 25, size 4 bytes written.
- Key: 29, size 6 bytes written.
- Key: 34, size 80 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 2.937 s
Old 06-29-2010, 15:35   #4 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
Andra sir need soluation..............plzzzzz
Old 06-29-2010, 15:43   #5 (permalink)
Member: 800668
Sonork: 100.1590720
Thanks Meter: 882
write pm by pm auth or post here proper log.
Br.
Shashank
Old 06-29-2010, 15:50   #6 (permalink)
naushad09's Avatar
Member: 216094
Thanks Meter: 321
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 120.88.39.138
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
Section: 309
- Key: 22, size 12 bytes written.
Completed in 2.797 s
Old 06-29-2010, 15:57   #7 (permalink)
Member: 1085109
Sonork: 100.1585163
Thanks Meter: 223
Simple.
Br.
Shashank
BROTHER I LL GIVE YOU A COMPLETE SOLUTION FOLLOW MY ALL INSTRUCATION
First you are repair sd like this ;
AND THEN PEPAIR SIM LOCK LIKE THIS WRITE CHECK ON PEPAIR SIM LOCK AND MAKE SIM LOCK RPL AND THEN CLICK ON PEPAIR SIM LOCK LIKE THIS
Uploaded with ImageShack.us
YOUR HAND SET WILL B 1000% OK TESTED BY ME DNT FORGET PRESS THANKX
The Following User Says Thank You to abdullah sheikh For This Useful Post:
Old 06-29-2010, 20:06   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
SIMLOCK invalid!
your phone only need to REPAIR SIMLOCK
then do PMM Auth + write PM (1) and (309)
br,
need ericsson 88 cable migdamas Old Ericsson Phones & Sony Phones 2 03-24-2017 16:24
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
need eeprom photo???? mobileinfo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-26-1999 11:35
Page generated in 0.20891 seconds with 10 queries
