10-04-2011, 00:30 | #1 (permalink) |
Junior Member Join Date: Oct 2011
Member: 1666037 Status: Offline Sonork: Aarón Galli Thanks Meter: 0 | Help flashing Nokia 2690 ## (ANSWERED) This is what I dis: 1. Backup RPL. 2. Backup Simlock RPL. 3. Backup PM 4. Full Erase. Now in trying to flash it, but can't do it. I tried with UFC4 and with USB. This are the logs: USB: MXKEY Serial: [FT SCR2000 0] - Connection status: UHCI:HUB:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.70 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm635__09.65.mcusw [BB5,BB5 ALGORITHM] size: 17.92 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 8CA4762 CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] CMT EM0 ID: 00000296 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 1D600015B38E0356E108256212AB0D66EC540BCB CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x49480 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x57AC0 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 8CA4762 Verifying communication to device... ERROR: Could not verify communication ! Failed to set phone to flashmode, possible reason: Update Agent not running or PASUBTOC corrupted ! Please recover phone using FBUS. And with UFC4 MXKEY Serial: [FT SCR2000 0] - Using device: HTI BOX, FW ver: 00.07 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: HTIBUS, ver: 3.4.7.0 , NTMP ver: 2.6.0.0 Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011) Processing MCU file: rm635__09.65.mcusw [BB5,BB5 ALGORITHM] size: 17.92 MB Supported Ids: 010C192101013000, 0103192101003000, 030C192101033000 CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 1D600015B38E0356E108256212AB0D66EC540BCB ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS is blank/erased. TransmissionMode: DDR&TX2 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 0.234 s Prog.status for Asic CMT ... NOR: Success Flash programming ... Error chk C7012D0103CD RX2 not responding, please check BSI/cable/pinout ! Error while programming [00] at 0x00040000, Result: 0000 Task failed at (0800001C)!!! Last RX buffer: C7 01 2D 01 03 CD 00 Any idea or solution? Please help |
10-04-2011, 02:45 | #2 (permalink) |
No Life Poster Join Date: Oct 2009 Location: Basirhat
Member: 1134419 Status: Offline Sonork: 100.1621725 Thanks Meter: 452 | Bro when you downgrade any set allays try to tick downgrade and use a good quality FBUS cable. |
The Following User Says Thank You to mridulnandy For This Useful Post: |
10-04-2011, 06:05 | #4 (permalink) |
Member: 1149800 Status: Offline Thanks Meter: 211 | it is cable problem... change the fbus cable or clean the pin out on the phone... then try to flash again using v9.65 or u can try flashing it using hwk instead. if done, then restore imei. good luck bro br |
10-04-2011, 06:10 | #5 (permalink) |
Registered User Join Date: Sep 2008 Location: HardWare+Software & Unlocking
Member: 865598 Status: Offline Sonork: 100.1609492 Thanks Meter: 465 | Bro use new fbus cable new verion flash file Blue-Nokia.com by Obnoxy to downlaod flash file letest and try full flash and Ui seting 100% ok................................... |
10-04-2011, 20:15 | #6 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
please check your cable. choose the correct one if you're using JIG type FBUS cable. BR | |
