07-06-2010, 10:15 | #1 (permalink) |
Freak Poster Join Date: Oct 2006 Location: NIGERIA
Member: 380077 Status: Offline Sonork: 100.1601214 Thanks Meter: 55 | help how can i flash n900 Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode SW version in image: RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'kernel', size 1705 kB Version 2.6.28-20101501+0m5 Image 'rootfs', size 173568 kB Version RX-51_2009SE_10.2010.19-1_PR_MR0 Image 'cmt-2nd', size 81408 bytes Version BB5_09.36 Image 'cmt-algo', size 519808 bytes Version BB5_09.36 Image 'cmt-mcusw', size 5826 kB Version rx51_ICPR82_10w08 Image '2nd', size 14720 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2217, 2218, 2219, 2220, 2120 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2101, 2102, 2103 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2307, 2308, 2309, 2310 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2407, 2408, 2409, 2410 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2301, 2302, 2303, 2304, 2305, 2306 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2401, 2402, 2403, 2404, 2405, 2406 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2104, 2105, 2106, 2107, 2108, 2109, 2110, 2111, 2112, 2113, 2114, 2115, 2116, 2117, 2118, 2119 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2501, 2502, 2503, 2504, 2505, 2506 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2607, 2608, 2609, 2610 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2507, 2508, 2509, 2510 Version 1.4.14.8+0m5 Image '2nd', size 14720 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2201, 2202, 2203, 2204, 2205, 2206, 2207, 2208, 2209, 2210, 2211, 2212, 2213, 2214, 2215, 2216 Version 1.4.14.8+0m5 Image '2nd', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'xloader', size 14848 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 Image 'secondary', size 109440 bytes Valid for RX-51: 2601, 2602, 2603, 2604, 2605, 2606 Version 1.4.14.8+0m5 with this as the phone flashed or not. regards |
07-06-2010, 17:25 | #2 (permalink) | |
No Life Poster Join Date: Apr 2009 Location: Mizoram>>Aizawl
Member: 1014781 Status: Offline Thanks Meter: 177 | Quote:
07-06-2010, 18:18 | #3 (permalink) |
No Life Poster Join Date: Oct 2007 Location: South Africa/Pakistan
Member: 619308 Status: Offline Sonork: 100.1591829 Thanks Meter: 243 | u r not exactly wrong.but mxkey also sport n900 flashing just select mcu file only. and then conect phone while holding U. |
12-09-2010, 04:50 | #4 (permalink) |
Member: 1012165 Status: Offline Thanks Meter: 116 | help bro problem flashing n900 ,it does not flash when i select only mcu,click flash then hold down u key till usb shows at right corner it just shows comleted without the phone flashing pls help log below Library version: 1.0.0.9019(20-11-2010), 1.0.0.15042(20-11-2010) Remove USB cable from device. Turn off the phone Press and hold down key 'u' Connect USB cable between the phone and host PC while still holding down key 'u' When USB cable gets connected it powers the phone and set's it to flashing mode Waiting for phones to boot up ... Flashing completed in 1 min 24.579 s Phone not responding ! |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
