02-24-2011, 11:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | INFO: How to repair security test failed all of us know that mxkey has perfectly solved contact service caused by security test failed some just too lazy to search if the phone is in contact service condition, and shows the log like this: SIMLOCK valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SECURITY_TEST failed! these are the steps to solve it: 1. First of all u need good pm with SX4 ( do SX4/super sd auth after that pm1 and pm309 ) 2. if not solved then check CCC and HWC certificates How to repair CCC and HWC certificates ? backup RPL than open it in notepad there u will see NPC data after that CCC data and HWC data just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model ) 3. if still not solved then recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON 4. if still not solved then Repair SL REPAIR SD SUPER SD AUTH write PM1 and PM309 5. if still same then make RPL backup full erase then flash then rpl then Repair SL then SD repair then super sd auth then PM 1 and 309 i just hope no more new threads started everyday asking about security test failed problem again good luck br ps: the solutions are quoted from this forum too, thanks to who posted for the 1st time, i forget who posted it before... Last edited by specta; 02-24-2011 at 11:36. Reason: add ps note |
The Following 6 Users Say Thank You to specta For This Useful Post: |
02-27-2011, 09:19 | #2 (permalink) |
Member: 1149800 Status: Offline Thanks Meter: 211 | additional: How to repair Superdongle ( phone restart in every 3 minutes): 1. if the log is like this: SIMLOCK invalid! SUPERDONGLE_KEY invalid! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST failed! SECURITY_TEST passed in this case, to solve it: a.press repair Super Dongle b.then SD Auth PM c.then write good pm including fields pm1 and pm309 d. update splock (by ticking init simlock & make simlock rpl) if needed (just for sl2) 2. if the log is like this: SIMLOCK passed! SUPERDONGLE_KEY passed! - WD timer enabled, phone will reboot itself after 3 min. SIMLOCK_TEST passed SECURITY_TEST passed in this case, to solve it: a.press repair Super Dongle b.then SD Auth PM c.then write pm1 and pm309 only (or u can tick load rfbb from server to write from server) if after repair sd, u found problem in security test failed, then u can try the steps mentioned above... good luck bro br |
02-02-2012, 08:50 | #7 (permalink) |
Member: 1149800 Status: Offline Thanks Meter: 211 | it is not too long bro, there are few options if u failed on one, but surely one of the options will solve your problem for sure. and don't forget the date i posted it, it was long long ago before hti was invented and no standalone sx4 br |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
