Old 02-10-2010, 08:47   #1 (permalink)
Member: 1230905
help me for 3110c SECURITY_TEST failed!
help me for 3110c
RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D
NPC verified Ok.
Updating CMT CCC ...OK
Updating CMT HWC ...failed, Result: 06A0000000317200
Certificate programmed successfully !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359343020990090
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-10-2010, 08:53   #2 (permalink)
Member: 1230905
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.11985, Date: 03-02-2010
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
ERROR: Missing SD BLOCK or PM corrupted !
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 0.969 s
Old 02-10-2010, 08:55   #3 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
1.do SX-4 and write PM without [308] area
in case after Superdongle repair , please use "SUPER SD Auth"
2.Check BB5 Secure Validation
[MXKEY - INFO] !!! NEW magic button inside mxkey !!!
this is have important info, where the real problem
3.do "Recover CERT" , if doesn't work
Begin Certificate Request ...
Connecting to server ...OK, Login ...
ERROR: No certificate found in the database !
check this
Just in case if Recovery via Server doesn't work.......
need more file about CCC,HWC and VARIANT
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 02-10-2010, 09:22   #4 (permalink)
Member: 1230905
ding RAP NPC (0x168 bytes)
Original Product Code: 0566963
Reading RAP VARIANT (0x0 bytes)
Reading RAP CCC (0x160 bytes)
Product Code: 0544321
Product Code missmatch !
Reading RAP HWC (0xD4 bytes)
HWC seems to be valid
Old 02-10-2010, 10:34   #5 (permalink)
Member: 1230905
check this
br,
RAP Data :
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 0CD00114FC257E56BA3D2214AA14A0BE8B13BC4C
ASIC MODE ID: 00
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Imei plain: 35934302099009-0
pls give solution for this error
Old 02-10-2010, 10:44   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,773
answer from here
E63-RM450 SECURITY_TEST failed!
Failed write HWC
Updating CMT HWC ...failed, Result: 0640000000317200
please delete FFFFFFFFF data
ex :
[CERT_PROG_DATA_OUT_CMT]
CCC_DATA_1=4343434302004150010000009138E0949B95CC491B5033000AAA9C00000060010000000080827947
CCC_DATA_2=00000000000000000000000000000000000000000000000000000000000000003035383237393543
CCC_DATA_3=803800470000000000000000030000000F0000008100000000000000000000000000000000000000
CCC_DATA_4=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_5=00000000000000000000000000000000000000000000000000000000000000000000000000000000
CCC_DATA_6=0000000000000000000000000000000000000000000000006CF146355A227E59DA0576F0B632FF5E
CCC_DATA_7=C43B78757EB5006482AA42C7BE4BE334A881630075A32EE42B0FC9E3E409216E1B4E995841DB59C1
CCC_DATA_8=D64FC7CE33283AEC9AB63423FB806C38EA5E6216CA455A6F098E7BDD3E5ABCBC165B4161941FA3B5
CCC_DATA_9=F47BDA0E33495A2BA6CBC683B60264D7FA16160A659C0E4312627D1752C1FC93FFFFFFFFFFFFFFFF
CCC_DATA_10=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CCC_DATA_11=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CCC_DATA_12=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
CCC_DATA_13=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HWC_DATA_1=43485743050041500100000006120298F412D2490B890400646F7242000000000000000000000000
HWC_DATA_2=000000009B95CC490A100209DD750052013ADE0055F5D81C2D8D942F303538323739354300000000
HWC_DATA_3=000000007A46CC58ED5C646B513264D61923938D852EBCF635A52580C0B550256351A133C064D29C
HWC_DATA_4=04F97268ED2AE83E5745B180BE374E0BFE9322D947AF6CA18D5BE8FD7B7144532C9FA3A0D8014EEC
HWC_DATA_5=A6C3948ED5F2704B7189C7C4E427B44B28EA0230DD31C8B19412E23279B600CD4ED6407A2361431E
HWC_DATA_6=96B033E4784AB192DFC2ACACFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
HWC_DATA_7=FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
after delete unused sector
and rewrite RPL data
br,
Old 02-10-2010, 11:56   #7 (permalink)
Member: 1230905
sir please dont mistake
how can i delete?
which option i want use to delete?
pls tel me step by step
thank you
3110C Security_test failed done with SuperSX4 auth server upadate bireun MXKEY Nokia Flasher and Unlocker (by Alim Hape) 20 09-09-2010 13:36
plz mx key help me for 3110c SERVER: Imei invalid or empty (12345610654321?)! boussoula MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 03-26-2010 12:58
help me for n91 satr-up failed AgicAga Universalbox 1 09-22-2008 08:56
Page generated in 0.29690 seconds with 8 queries
