Old 05-15-2010, 07:03   #1 (permalink)
Member: 741287
Thanks Meter: 15
Arrow help me Bad phones ack on step1
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 07.21 05-11-08 RM-237 (c) Nokia.
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
any solution plase...............
Old 05-15-2010, 07:07   #2 (permalink)
Member: 982335
Thanks Meter: 202
uninstall mx key....delete all file from c drive install again.....sign in....then try again.
post result......must.
Old 05-15-2010, 08:47   #3 (permalink)
Member: 741287
Thanks Meter: 15
not work for me.i test
install again .....sign in....
try but facing same problem
Old 05-15-2010, 09:05   #4 (permalink)
Member: 982335
Thanks Meter: 202
u repair sd before doing sd auth/pmm auth?
plse reply.
Old 05-15-2010, 09:17   #5 (permalink)
Member: 376471
Sonork: 100.1608095
Thanks Meter: 107
Dear Member...........
Take cert backup with ufs.......... Full erase the phone with mxkey.............
Flash v7.30 with ufs and the restore only NPC Cert with ufs.....
Write mxkey rpl collection without NPC to ur phone................
Do Bus check with mxkey..........Analyse the problem and do necessary steps to alive the phone.........
If the problem shows SD Key invalid and Security test failed......... 1st do SD Repair option.............. Then do Bus Check.............. If then shows Security Test Failed then write RF/BB settings from server by clicking Super SD Auth......... If not solved Write PM 1 and 309 from working phone.............. This will solve..............
Old 05-15-2010, 09:23   #6 (permalink)
bipugunjan's Avatar
Member: 526223
Sonork: 100.1605395
Thanks Meter: 106
help me plz..................
Old 05-15-2010, 09:30   #7 (permalink)
Crazy Poster
Member: 1302158
Thanks Meter: 16
7210c Bad phones ack on step1
i cannot use super sd auth, always bad phone ack on step 1, i already uninstall mx key, ang install again, use repair sd and then super sd auth, result same
Product: V 07.23 17-07-09 RM-436 (c) Nokia
Using cached productData[0220010927FD7C56030D3B9EA0A6BE1124CEE1F8] ...
anyone help me?>
Old 05-15-2010, 09:35   #8 (permalink)
Member: 982335
Thanks Meter: 202
bro
try with working phone & if super sd auth/pmm auth working or not?
post result.
i try with ok phone super sd function giving error but pmm auth worked...
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.0
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 218.248.80.52
SUPERDONGLE authorized !
Writing PM from Node ...
Section: 1
- Key: 0, size 12 bytes written.
- Key: 2, size 70 bytes written.
- Key: 3, size 70 bytes written.
- Key: 4, size 70 bytes written.
- Key: 6, size 276 bytes written.
- Key: 7, size 256 bytes written.
- Key: 10, size 384 bytes written.
- Key: 11, size 384 bytes written.
- Key: 14, size 384 bytes written.
- Key: 17, size 32 bytes written.
Section: 309
- Key: 0, size 4 bytes written.
- Key: 1, size 2 bytes written.
- Key: 2, size 12 bytes written.
- Key: 4, size 12 bytes written.
- Key: 5, size 12 bytes written.
- Key: 7, size 12 bytes written.
- Key: 8, size 12 bytes written.
- Key: 17, size 12 bytes written.
- Key: 22, size 12 bytes written.
Completed in 1.000 s
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 09:14
Help with 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-25-2009 17:29
Page generated in 0.32785 seconds with 8 queries
