Old 10-17-2012, 12:09   #1 (permalink)
Member: 680660
Thanks Meter: 2
help me mx-key No SX4 Card found.
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
Imei plain: 35572802841552-6
Product code: 0552816
Battery voltage: 4885 mV, current: 57 mA
Language Pack:
- not available.
SLPA ver[1]: PA_SL (15 digit NCK)
SIMLOCK seems to be valid
SUPERDONGLE_KEY[MX] seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei net: 355728028415526
Version: SIMLOCK SERVER VERSION 63
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK1: 1=CLOSED(MCCMNC), DATA=00101F
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->MXKEY - BLADE X at host1, agent version 1.2 revision 0.5
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Retrying ...
Authenticating using security server ...
Retrying ...
Retrying ...
Looking forward to your help support
Old 10-17-2012, 12:18   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Bro.
Instead of PMM Auth, just follow this,
Go to Service Tab > Click Load from File > Select Address: C:\mobileEx\3.5\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb & Select RM-237.PM file,
Now click Repair SD & click no to Pop Up Window, Click Write & Buscheck you will see the positive Result.
BR,
ZUBER
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 12-02-2012, 04:54   #3 (permalink)
Member: 1502738
Originally Posted by .::ZUBER::. View Post
Bro.
BR,
ZUBER
thanks br,good solution
Old 12-02-2012, 08:20   #4 (permalink)
Member: 4483
Thanks Meter: 5
Work on N6630 rm-1...
Page generated in 0.20870 seconds with 7 queries
