Old 08-15-2010, 15:19   #1 (permalink)
Member: 1234957
Thanks Meter: 2
Exclamation Help Me Mx-key Team
Using device: UFS3 SarasSoft
» UFxBoot V2.2 (c) SarasSoft 2003.
» UFS_USB V2.8 (c) SarasSoft 2007.
Serial: C08316AC
FW version: 00.20
Counter remain: 99.57%
Licenses: 0 = True
1 = True
2 = True
DCT4PLUS License: True
Registered to: deepakfullara
How Can I repair corrupted IMEI for Nokia Dct4 phones
Online Logger not working
Plz its urgent
Are there any credits, if yes how can I use them
Thanx in Advance
Old 08-15-2010, 15:34   #2 (permalink)
Member: 862260
Sonork: 100.1612919
Thanks Meter: 156
bro mx logar is working try with mx key
The Following 2 Users Say Thank You to master2009 For This Useful Post:
Old 08-15-2010, 15:58   #3 (permalink)
Member: 1234957
Thanks Meter: 2
Unhappy
Logger Not working i try several times
The Following User Says Thank You to lionheartdeepak For This Useful Post:
Old 08-15-2010, 16:04   #4 (permalink)
>Amit<'s Avatar
Member: 1359320
Sonork: 100.1620477
Thanks Meter: 79
reinstall the mxkey delete the folder of mxkey from c and after that install and virify sign the application after that all will be ok try it bro me tested
Old 08-15-2010, 16:06   #5 (permalink)
Member: 1234957
Thanks Meter: 2
Serial: C08316AC
FW version: 00.20
Licenses: 0 = True
1 = True
2 = True
Phone Type: RH-105
SW Version: V 6.00 30-09-09 RH-105 (c) NMP
Imei plain: ??????????????-?
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: MG
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: 00000000000000
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 0000000000000000
PROFILE_BITS: 0000000000010000
SIMLOCK_DATA corrupted!
Old 08-15-2010, 16:12   #6 (permalink)
Member: 862260
Sonork: 100.1612919
Thanks Meter: 156
first select server then try
Old 08-15-2010, 17:17   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
hi,
next time please use your searching button, that is very usefull
this time please begin with read carefully this thread
http://forum.gsmhosting.com/vbb/f550...ftware-747426/
br,
The Following User Says Thank You to Andra For This Useful Post:
Old 08-17-2010, 16:08   #8 (permalink)
Member: 1234957
Thanks Meter: 2
Exclamation
Help Me "Sorry Application expired"
using v3.4(rev1.0)
where is problem
Old 08-17-2010, 20:45   #9 (permalink)
Cheater -Don't Deal with him-
Member: 1179761
Sonork: 100.1602000
Thanks Meter: 1,834
Arrow
using v3.4(rev1.0)
where is problem
Always use latest version, problem solved
Use latest & last version
The Following User Says Thank You to nerobdms™ For This Useful Post:
Old 08-18-2010, 14:46   #10 (permalink)
Member: 1234957
Thanks Meter: 2
Can I repair Sl3 based phones with NPC data Ok but on contact service?
Help me Mx key Team
Old 08-18-2010, 14:50   #11 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
Help me Mx key Team
where is your log info from phone ?
br,
Old 08-18-2010, 15:18   #12 (permalink)
Member: 1234957
Thanks Meter: 2
Exclamation
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
Processing file: rm495__07.95.mcusw as MCU
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported RAP Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 12B0021608F58A5609406468C3049538E36E5DA3
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
No RAP Flash Chip Detected
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...Error
Flashing terminated with error(s) in 42.100 s
RX Buffer: 0400000000B172
Help Me
Old 08-18-2010, 15:19   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
check your cable first.
mostly is from hardware damage.
br,
Old 08-21-2010, 13:07   #14 (permalink)
Member: 1234957
Thanks Meter: 2
1208 rf chip id test failed
Is it hardware or software problem help me?
Phone has low signal problem & no incoming calls
Old 08-21-2010, 15:57   #15 (permalink)
Member: 923622
Thanks Meter: 10
is it hardware or software problem help me?
that problem from hardware bro
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
Eeprom dump lost, help needed. CAMILO Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 11-29-2010 19:04
Page generated in 0.29522 seconds with 9 queries
