Old 07-22-2009, 08:00   #1 (permalink)
Mallick Manzil's Avatar
Member: 1074634
Sonork: 100.1583894
Thanks Meter: 241
Unhappy Help me MX-KEY team & all mambers
hi mx_key team
3110c set only restart when i receive
i wanna go to flash then set is dead
now then i click bus check give me this massage
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM1 ID: 00000232
EM2 ID: 00000353
PUBLIC ID: 18100003804B7E5694B37F236577081826805B0B
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
rap3gv3_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8981 - 0000 0000 [Intel ] type: NOR,RAP
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
ExtDEVC: FFFF 0000 - 0000 0000
RAP3Gv3_algo.fg: [BB5 ALGORITHM] version: 1.33.1 revision: 0.0 size: 0x29878
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS is blank/erased.
Original Imei: 00000000000000
Original Product code:
CLICK FLASH
Processing file: rm237__07.21.mcusw
RAP Data :
EM1 ID: 00000232
EM2 ID: 00000353
ASIC MODE ID: 00
Programming MCU ...
rm237__07.21.mcusw:
[BB5,BB5 ALGORITHM] size: 14.48 MB
Supported RAP Ids: 0103192101001101, 010C192101001101
Total erase size: 16.37 MB
CMT NOR area [00000000-000006BF]
CMT NOR area [000006C0-0001FFFF]
CMT NOR area [00020000-0007FFFF]
CMT NOR area [00080000-000DFFFF]
CMT NOR area [00100000-001FFFFF]
CMT NOR area [00200000-0031FFFF]
CMT NOR area [00320000-0105FFFF]
CMT NOR area [01060000-01067FFF]
CMT NOR area [01068000-0107FFFF]
erasing ...
Error while erasing, Result: 00000000000000 , 0
Flashing terminated with error(s) in 23.250 s
RX Buffer:
Old 07-22-2009, 08:06   #2 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Thanks Meter: 3,949
JUST CLICK ON RX2 AND ENABLE IT
THEN AGAIN TRY TO FLASH IT HOPE ALL WILL BE OK
WBR
sahil2000ind
Old 07-22-2009, 08:08   #3 (permalink)
sajidali's Avatar
Member: 181886
Sonork: 100.1579817
Thanks Meter: 1,007
try to enable rx2 option brother.and post result
Old 07-22-2009, 16:31   #4 (permalink)
Member: 1074634
Sonork: 100.1583894
Thanks Meter: 241
i try
I try to enabel rx2 ,and change box but same...no luck
Old 07-22-2009, 16:41   #5 (permalink)
didin yulian's Avatar
Member: 239081
Thanks Meter: 253
1.cable
2.cable
Old 07-22-2009, 16:45   #6 (permalink)
arifksarmali's Avatar
Member: 259084
Thanks Meter: 232
i have same problem i alredy damge one 3110c by this
Old 07-22-2009, 17:15   #7 (permalink)
Member: 239081
Thanks Meter: 253
try flashing with usb...&make sure that u r rpl has bekup first
Old 07-22-2009, 19:44   #8 (permalink)
1NOKIA1's Avatar
Member: 946569
Thanks Meter: 326
Solution tested by me
http://forum.gsmhosting.com/vbb/show...88&postcount=2
The Following User Says Thank You to 1NOKIA1 For This Useful Post:
Old 07-23-2009, 05:39   #9 (permalink)
Member: 486967
Sonork: none
Thanks Meter: 17
yup cable or use other fias in the mx key folder
Old 07-23-2009, 07:19   #10 (permalink)
rajufzr's Avatar
Member: 116314
Thanks Meter: 147
this problem only ion new 3110 only. first flash it to 6.60 version all ok. if u need to upgrade it to latest then only u can to 7.21. tested many times.
3110c contact service.PLEASE help me MX-KEY team VIBINDAS_INDIA MXKEY Nokia Flasher and Unlocker (by Alim Hape) 22 06-19-2011 13:42
Help me mx key team ..::Rizwan::.. MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-22-2010 12:24
help me mx-key team Jilani001 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 11-30-2009 13:42
Plz help me MX KEY TEAm amar181 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 06-30-2009 19:34
Page generated in 0.20290 seconds with 9 queries
