Old 10-11-2012, 07:29   #1 (permalink)
Member: 403881
Thanks Meter: 80
Request for MXkey Team
I am getting problem in BUS CHECK with almost all DCT4 sets are showing problem.I have attached 2 picture its ok with UFS but problem with MXkey please suggest what may the problem.
Regards,
Old 10-11-2012, 07:57   #2 (permalink)
Member: 161280
Sonork: 100.1616990
Thanks Meter: 82
Regards,
try to use auto soft resistor then post result
Old 10-11-2012, 08:10   #3 (permalink)
Member: 403881
Thanks Meter: 80
I could not mean you,What is auto soft resister i use normal GPG cable. Any way thanks for reply.
Old 10-11-2012, 08:17   #4 (permalink)
Member: 714648
Sonork: 1609640
Thanks Meter: 931
Set SOFT TMA RESISTOR To 8mhz
then try to bus check
see pict :
br,
The Following 2 Users Say Thank You to mr.omphonx For This Useful Post:
Old 10-18-2012, 06:13   #5 (permalink)
Member: 403881
Thanks Meter: 80
Thanks for your support but let me check and reply.
Old 10-18-2012, 07:01   #6 (permalink)
Member: 403881
Thanks Meter: 80
solution not working
see pict :
br,
No the solution provide by the PRODUCT SUPPORTER is not working here two picture of one 5030 set the set was dead and it got ON after flashing with UFS but in MXKEY it showing error.
Page generated in 0.20354 seconds with 9 queries
