Old 01-21-2011, 08:42   #1 (permalink)
Member: 772040
Thanks Meter: 12
Help Please Nokia 5130c Nokia White Screen Off
Please help me with this phone I tried to flash it start 7.95,7.96,7.97 but still no Luck can any body give me a solution to this problem Master...
Self Test
Phone Type: RM-495
SW version: V 07.97 13-09-10 RM-495 (c) Nokia
ID Test name Startup Result
3 EAR_DATA_LOOP Y PASSED(00)
12 SIM_CLK_LOOP Y PASSED(00)
13 SIM_IO_CTRL_LOOP Y PASSED(00)
15 SLEEP_X_LOOP Y PASSED(00)
46 UEM_CBUS_IF Y PASSED(00)
7 KEYBOARD_STUCK N !NOT EXECUTED(03)
22 CAMERA_IF N !NOT EXECUTED(03)
20 BACKUP_BATT N !NOT EXECUTED(03)
43 LCD N !NOT EXECUTED(03)
21 LPRF_IF N !NOT EXECUTED(03)
44 LPRF_AUDIO_LINES N !NOT EXECUTED(03)
2 CURRENT_CONS N !NOT EXECUTED(03)
42 RADIO N !NOT EXECUTED(03)
69 BACKLIGHT Y PASSED(00)
33 SIM_LOCK N PASSED(00)
93 SECURITY N PASSED(00)
71 BT_WAKEUP N !NOT EXECUTED(03)
96 HOOKINT N !NOT EXECUTED(03)
88 TAHVOINT Y PASSED(00)
101 BTEMP N !NOT EXECUTED(03)
119 IIC N !NOT EXECUTED(03)
108 EXT_DEVICE N !NOT EXECUTED(03)
56 CDSP_SLEEPCLK_FREQ N !NOT EXECUTED(03)
128 CDSP_SLEEPCLOCK_FREQ N !NOT EXECUTED(03)
86 CDSP_RF_BB_IF N !NOT EXECUTED(03)
83 CDSP_RF_SUPPLY N !NOT EXECUTED(03)
80 CDSP_TX_PLL_PHASE_LOCK N !NOT EXECUTED(03)
81 CDSP_RX_IQ_LOOP_BACK N !NOT EXECUTED(03)
77 CDSP_GSM_TX_POWER N !NOT EXECUTED(03)
Flash it with 7.97
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.9113(26-12-2010), 1.0.0.15152(26-12-2010)
Processing MCU file: rm495__07.97.mcusw
[BB5,BB5 ALGORITHM] size: 18.20 MB
Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 06D0010F947D4950371925B26DBD0B402B3E8020
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 00EC 2400 - 0000 8A31 [Samsung ] type: NOR,CMT
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
TransmissionMode: DDR&TX2
Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK
Erase size: 21.00 MB
CMT NOR area [00000000-000006BF] erased in 0.585 s
CMT NOR area [000006C0-0001FFFF] erased in 0.154 s
CMT NOR area [00040000-000BFFFF] erased in 2.015 s
CMT NOR area [000C0000-0013FFFF] erased in 0.222 s
CMT NOR area [00140000-0137FFFF] erased in 22.581 s
CMT NOR area [01380000-0151FFFF] erased in 6.648 s
Flash programming ...
CMT PAPUBKEYS: 0C917F11196FDB7378C18EF7260698CA4489DCA0 (RAP Certificate 164 v.1) written.
Programming completed in 11 min 50.269 s
Processing PPM file: rm495__07.97.ppm_s
[BB5,BB5 ALGORITHM] size: 8.02 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 8.62 MB
CMT NOR area [01520000-01DBFFFF] erased in 24.349 s
Programming completed in 5 min 25.328 s
Processing CNT file: rm495__07.97.image_s_red
[BB5,BB5 ALGORITHM] page size: 128 K size: 12.89 MB
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
Erase size: 34.00 MB
CMT NOR area [01DC0000-0215FFFF] erased in 14.834 s
CMT NOR area [02160000-03FBFFFF] erased in 52.338 s
Programming completed in 8 min 31.846 s
Total time for flashing process(boot+erase+write) was 28 min 42.126 s
Flashing completed in 29 min 3.029 s
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 07.97 13-09-10 RM-495 (c) Nokia
Imei plain: 35152104700621-8
Product Code: 0571949
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351521047006218
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
But still show Nokia to white Screen then off... Kindly Help me please....
Old 01-21-2011, 08:55   #2 (permalink)
Member: 110476
Sonork: d76272cd1b04650aee14d04e7
Thanks Meter: 38
hardware,,...............
The Following User Says Thank You to dawgweed For This Useful Post:
Old 01-21-2011, 08:57   #3 (permalink)
adityajha's Avatar
Member: 1183572
Thanks Meter: 203
remove camera and see result.
The Following User Says Thank You to adityajha For This Useful Post:
Old 01-21-2011, 09:01   #4 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
Its a hardware problem bro u need to search the forum for the proper guidance.
The Following User Says Thank You to pallumobile For This Useful Post:
Page generated in 0.20515 seconds with 9 queries
