09-21-2012, 15:12 | #1 (permalink) |
No Life Poster Join Date: Jun 2008 Location: dunja
Member: 786607 Status: Offline Thanks Meter: 66 | help with rpl have bought rpl now to repair solution pls see log MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C08xxxxx Using device: HTI, FW ver: 00.50, SN: 010057F2 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ERROR: Packet Error(0xAA), code 0xC0000001 CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 13F0000A6A620344A8CA77DFE7DD088512AF3147 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Selected firmware certificate matched. Original Imei: 35823803041606 Original Product code: 0586955 Bluetooth ID: 1886AC4C68CB SIMLOCK PA identifier: [0] PA_SL3 Phone type: RM-470 (Nokia 6700 classic) SW version: V 13.21 12-01-11 RM-470 (c) Nokia Imei plain: 35823803041606-3 Product code: 0586955 Battery voltage: 4771 mV, current: 155 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST failed! SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-21-2012, 15:44 | #3 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | look bro same when writ rpl ERROR: Packet Error(0xAA), code 0xC0000001 Imei: 35823803041606 Updating SIMLOCK(PA_SL3)...error 0x7 Trying to write SIMLOCK as PM(PA_SL3)...OK MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C086FF92 Using device: HTI, FW ver: 00.50, SN: 010057F2 Connection status: OHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) ERROR: Packet Error(0xAA), code 0xC0000001 CMT Data : SYSTEM ASIC ID: 000000030000022600010007600C192102011104 [RAPUYAMA ver: 1.1] EM0 ID: 00000C34 EM1 ID: 00000C30 PUBLIC ID: 13F0000A6A620344A8CA77DFE7DD088512AF3147 ASIC MODE ID: 00 ROOT KEY HASH: 25B977A055BE9B5DEC0C38A2A279C695 ROM ID: 3E273BF637BE26FA SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 12.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 12.14.0 revision: 3.0 size: 0xD4569 Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: CABA40E42B6F3B8A6EFEE35B4A9D15924EB132C6 Updating CMT NPC ...OK Updating CMT CCC ...OK Updating CMT HWC ...OK Prog.status for Asic CMT ... NAND: OK Phone type: RM-470 (Nokia 6700 classic) SW version: V 13.21 12-01-11 RM-470 (c) Nokia Imei plain: 35823803041606-3 Product code: 0586955 Battery voltage: 4799 mV, current: 155 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
09-21-2012, 16:00 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ Flash it before Writing RPL, Works in this cases. BR, ZUBEr |
09-21-2012, 21:02 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | You getting Problem while writing direct RPL, So Write RPL after Erase & Full Flash, must solve it. BR, ZUBER |
09-22-2012, 19:43 | #9 (permalink) |
Member: 786607 Status: Offline Thanks Meter: 66 | [cert_prog_data_out_cmt] npc_data_1=cbfc673f0000415000000000000000000000000 00000000000000000303538363935354300000000 npc_data_2=000000000000000000000000850702984449c94 acee66a00646f72420000000013f0000a6a620344 npc_data_3=a8ca77dfe7dd088512af3147caba40e42b6f3b8 a6efee35b4a9d15924eb132c6c0e029b05ab587de npc_data_4=135469ba943df993a04ee8d2000000000000000 000000000000000000200000047534d0000000000 npc_data_5=3385320803140636fffffffffffffffffffffff fffffffffffffffffffffffff42545f4944000000 npc_data_6=cb684cac8618000000000000000000000000000 0000000000000000000000000b6498d4b824aeab4 npc_data_7=a3bb3a5fc11188be0aead7d60d0338724fe5071 47591d646f82279e0ee9bcfdd37dbc6098179b396 npc_data_8=82d632c58346ee5cb5333b53b958f9888456797 6f1f4806a7e76ec638e525b32289b95f3cd73d0c3 npc_data_9=7220db1144449c6aff7d9a5b647be93a28026ce 731fcf9b40ee4036f302b57078cc193e31f8b81dd ccc_data_1=4343434302004150010000009138e094fb2a4b4 aacd73c0061279c00000060010000000000000000 ccc_data_2=000000000000000000000000000000000000000 00000000000000000000000003035383639353543 ccc_data_3=505879470000000000000000030000000f00000 08300000000000000000000000000000000000000 ccc_data_4=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 ccc_data_5=000000000000000000000000000000000000000 00000000000000000000000000000000000000000 ccc_data_6=000000000000000000000000000000000000000 000000000483f641dcb97b3651f7660dc84c04c25 ccc_data_7=9fd6eef5f102b7d6dd3d0038eb28c2cbf5f2e8e b74a69e0cf17dd70749223a3aaa6ca38e23755434 ccc_data_8=161c7c2f4241f78b79d28d63488a5b39d9886c0 466ccc77ccd38184e41b1f0b557ee6ca47daf411e ccc_data_9=43f6f11daddf9e012143efc8c89f1692d305513 dba7b8741a32d21a9b1be4605 hwc_data_1=434857430500415001000000850702984449c94 a3ee46a00646f7242000000000000000000000000 hwc_data_2=000000000000000013f0000a6a620344a8ca77d fe7dd088512af3147303538363935354300000000 hwc_data_3=00000000cd68b81ba0fd79c9602301af2792f7b f4e9dfd8e49a4c0c16db62fb5d0dba21b015af5f7 hwc_data_4=496b31328618b4d89e2f0b2acf2961cc19a9a5e f2d3350843483e0eac224f5abde9d29e69dd6450e hwc_data_5=6b2e0b5c0fae05239aeb92c4d69a5bbbf2d8c48 1df72ed37e1bf049f473e0189ee88eb14d23d132a hwc_data_6=150784e06a6ffb36ae422ec9 simlock_data_1=03917d58bea6f1d520d9112bee3810f6d28 9c4fb8000000000000002244070000000000000180700 simlock_data_2=000000000050000005ffffff00b4000005f fffff0118000005ffffff017c000005ffffff01e00000 simlock_data_3=05ffffff0244000005ffffff02a8000005f fffff000000007fff6f07fffffffff800030c03000503 simlock_data_4=000000007fff6f3effffffffc000030f020 00103000000007fff6f3fffffffffc000031102000103 simlock_data_5=000000007fff6f07ffffffff07fe0313080 00503000000007fff6f07ffffffff07fe031b08000503 simlock_data_6=000000007fff6f07fffffffff8000323030 00503000000007fff6f3effffffffc000032602000103 simlock_data_7=000000007fff6f3fffffffffc0000328020 00103000000007fff6f07ffffffff07fe032a08000503 simlock_data_8=000000007fff6f07ffffffff07fe0332080 00503000000007fff6f07fffffffff800033a03000503 simlock_data_9=000000007fff6f3effffffffc000033d020 00103000000007fff6f3fffffffffc000033f02000103 simlock_data_10=000000007fff6f07ffffffff07fe034108 000503000000007fff6f07ffffffff07fe034908000503 simlock_data_11=000000007fff6f07fffffffff800035103 000503000000007fff6f3effffffffc000035402000103 simlock_data_12=000000007fff6f3fffffffffc000035602 000103000000007fff6f07ffffffff07fe035808000503 simlock_data_13=000000007fff6f07ffffffff07fe036008 000503000000007fff6f07fffffffff800036803000503 simlock_data_14=000000007fff6f3effffffffc000036b02 000103000000007fff6f3fffffffffc000036d02000103 simlock_data_15=000000007fff6f07ffffffff07fe036f08 000503000000007fff6f07ffffffff07fe037708000503 simlock_data_16=000000007fff6f07fffffffff800037f03 000503000000007fff6f3effffffffc000038202000103 simlock_data_17=000000007fff6f3fffffffffc000038402 000103000000007fff6f07ffffffff07fe038608000503 simlock_data_18=000000007fff6f07ffffffff07fe038e08 000503000000007fff6f07fffffffff800039603000503 simlock_data_19=000000007fff6f3effffffffc000039902 000103000000007fff6f3fffffffffc000039b02000103 simlock_data_20=000000007fff6f07ffffffff07fe039d08 000503000000007fff6f07ffffffff07fe03a508000503 simlock_data_21=ffffffffffffffffffffffffffffffffff ffffffffffffffffffffffffffffffffffffffffffffff simlock_data_22=ffffffffffffffffffffffffffffffffff ffffffffffffffffffffffffffffffffffffffffffffff simlock_data_23=ffffffffffffffffffffffffffffffffff ffffffffffffffffffffffffffffffffffffffffffffff simlock_data_24=ffffffffffffffffffffffffffffffffff ffffffffffffffffffffffffffffffffffffffffffffff simlock_data_25=ffffffff simlock_key_data_1=0100000000004a2b6b657b22d0f415f 5df8a9e21462defd3648790e28301dbc0be7ea748eb0e4780 simlock_key_data_2=bbd501539ef4b43dc8bf5ad1e21eda6 89de786030c3666fcc131e4cba9dfc707206d4f79030a0ad7 simlock_key_data_3=decbb8f8ef3df645fc1948d93f2166c ddaa6e079f188163b220d0f4c90d4be026379666d4f2d281c simlock_key_data_4=dd1ffa37a4d8c9475be4696f050600f 281984f2a0ae46771bdc99fedca964f9cb23d41b1ed981cd8 simlock_key_data_5=dc0529af62fb13f0000a6a |
