04-30-2013, 08:44 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | help to unlock 6500 SL2 thanks MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: xxxxxxx Using device: USB ROM and HTI, FW ver: 00.50, SN: xxxxxxxx Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Processing MCU file: rm240__09.40.mcusw [BB5,BB5 ALGORITHM] size: 20.36 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] CMT EM0 ID: 00000295 CMT EM1 ID: 00000B22 CMT PUBLIC ID: 04F0000E543651504C6C4205122D0A5F8297C0FE CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 CMT ROM ID: 273F6D55DFAAF68F Flashing CMT Update Server Data, ULO: 0x3900 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, UPDAPP: 0x46F40 bytes Update Server code succesfully sent to phone. Flashing CMT Update Server Data, PASUBTOC: 0x55500 bytes Update Server code succesfully sent to phone. Waiting for USB device removal ... Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 35EC6267 Verifying communication to device OK. Erase size: 21.87 MB CMT FLASH,NOR area [00000000-0001FFFF] erased in 0.734 s CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.484 s CMT FLASH,NOR area [000C0000-0013FFFF] erased in 0.094 s CMT FLASH,NOR area [01480000-015FFFFF] erased in 7.219 s CMT FLASH,NOR area [00140000-0147FFFF] erased in 1 min 26.422 s Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent Selecting first CMT PAPUB block with matching RootKey. CMT PAPUBKEYS: A69838E8 [RAP Certificate 84 v1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Programming completed in 2 min 19.000 s Processing PPM file: rm240__09.40.ppm_t [BB5,BB5 ALGORITHM] size: 6.16 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 6.75 MB CMT FLASH,NOR area [01600000-01CBFFFF] erased in 31.875 s Flash programming ... Programming completed in 44.203 s Processing CNT file: rm240__09.40.image_vg_au [BB5,BB5 ALGORITHM] page size: 128 K size: 11.89 MB Supported Ids: 0103192101003000, 010C192101003000, 030C192101023000 Erase size: 34.87 MB CMT FLASH,NOR area [01FC0000-03F9FFFF] erased in 1 min 5.781 s CMT FLASH,NOR area [01CC0000-01FBFFFF] erased in 20.125 s Flash programming ... Programming completed in 1 min 11.515 s Total time for flashing process(boot+erase+write) was 8 min 28.906 s Waiting for USB device removal ... Waiting for device boot up ... Device connected: nmwcdc\Nokia 6500 slide USB Phonet, PORT_ID: 177A3588 Verifying communication to device OK. Phone type: RM-240 (Nokia 6500s-1) SW version: V 09.40 10-11-08 RM-240 (c) Nokia Imei plain: 35640002169003-9 Product code: 0556751 Battery voltage: 3687 mV, current: 154 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356400021690039 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] Market items is empty, please select the correct products path ! |
05-01-2013, 05:07 | #6 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | BUS CHECK MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C0880974 Using device: HTI, FW ver: 00.50, SN: 010118A6 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 04F0000E543651504C6C4205122D0A5F8297C0FE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0001 003F - 0000 8A21 [AMD 72NS512PD,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: A69838E8C5F20150E64E2E6E06DE6E50B26B593F TransmissionMode: DDR&TX2 Original Imei: 35640002169003 Original Product code: 0556751 Bluetooth ID: 002266BD2038 SIMLOCK PA identifier: [0] PA_SL2 Phone type: RM-240 (Nokia 6500s-1) SW version: V 09.40 10-11-08 RM-240 (c) Nokia Imei plain: 35640002169003-9 Product code: 0556751 Battery voltage: 4728 mV, current: 76 mA Language Pack: - not available. SLPA ver[2]: PA_SL2 (15 digit NCK) SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 356400021690039 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] UPDATE SIMLOCK Imei net: 356400021690039 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C0880974 Using device: HTI, FW ver: 00.50, SN: 010118A6 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) Phone type: RM-240 (Nokia 6500s-1) SW version: V 09.40 10-11-08 RM-240 (c) Nokia CMT Data : SYSTEM ASIC ID: 000000010000022600010006010C192101003000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 04F0000E543651504C6C4205122D0A5F8297C0FE ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 273F6D55DFAAF68F ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 Reading Simlock info ... Imei net: 356400021690039 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 8000000000000000 BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] |
05-02-2013, 02:33 | #8 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Hi, it's writen clear there Quote:
2. slide BSI to zero 3. check pins and cable connection | |
