04-03-2013, 03:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2007
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | help to unlock Nokia 2220s RM 590 |
04-03-2013, 06:38 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Post Buscheck Logs or Screen Shot of Error, Check or change Cable, mostly cause for Buscheck. BR, ZUBER |
04-05-2013, 14:08 | #3 (permalink) | |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | Quote:
MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: xxxxxxxxxx Using device: HTI, FW ver: 00.50, SN:xxxxxxxxx Connection status: EHCI:HUB:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012) ERROR: Packet Error(0xAA), code 0xC0000002 ERROR: Packet Error(0xAA), code 0xC0000002 Error details: Bad contact, TX line remains low ! VCC_PH BSI TX RX RX2 CLK 1 0 0 1 1 0 ERROR: bootstrap failed! | |
04-06-2013, 08:44 | #6 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
04-07-2013, 22:35 | #8 (permalink) |
Member: 453916 Status: Offline Sonork: 100.1620840 Thanks Meter: 246 | i dont Buscheck i only directly to Service Imei net: 35740204770308 Version: SIMLOCK SERVER Provider: Vodafone Network Pty. Ltd. , Country: Australia Counter: 0/3, 0/10 CONFIG_DATA: 5050300014981890 PROFILE_BITS: 800000000003000B BLOCK1: 1=CLOSED(MCCMNC), DATA=50503F [Australia-Vodafone Network Pty. Ltd. ] Calculating SIMLOCK RPL ... Rpl backup saved to "C:\mobileEx\3.5\data\backup\RM-590_35740204770308_SIM.RPL" Updating SIMLOCK ...OK Reading Simlock info ... Imei net: 35740204770308 Version: SIMLOCK SERVER Provider: GSM Test Operator Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 000000000003000B BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN |
