10-06-2012, 19:25 | #3 (permalink) |
No Life Poster Join Date: Oct 2009 Location: NIGERIA
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Actually it is my personal phone. I powered it 2 days ago and it came on and went off.i thought it was battery but after charging battery ful it repeated so i flashed it but it refused to enter local mode,then i erased wt infinity best bf mxbox. Right nw if u press power it wl just vibrate and nothing else.pls help me.thanks. |
10-06-2012, 19:47 | #4 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Post Buscheck Logs, Have you taken Backup RPL All Sections before Erase? If taken, then follow Erase from here: http://forum.gsmhosting.com/vbb/f550...an-do-1443542/ , Download Latest Firmware of your Phone Product Code & Flash it, Write PM & then Restore IMEI, Make Full Reset must work for you. Good Luck. BR, ZUBER |
10-07-2012, 01:32 | #5 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | Thanks but i just did exactly as u asked me but i has refused to enter local mode. Both with fbus and usb cables. Pls do u have any more suggested solutions? |
10-07-2012, 01:47 | #6 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | @ ZUBBA,THIS IS BUSCHECK LOG. MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C08067FA Using device: HTI, FW ver: 00.50, SN: 0100ADEA Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 19D00115DB8B10528BCDD7F594D55F2CDBDC98A3 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 12.8.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0050 - 0000 0031 [ST ] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0050 - 0000 0031 [ST ] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 12.8.0 revision: 2.0 size: 0x8B49D Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 505A5C85580A6322C103BFE4E67B73EF478E791C Original Imei: Empty Original Product code: Empty NPC_DATA invalid ! SIMLOCK PA identifier: [0] PA_SIMLOC30 |
10-07-2012, 01:49 | #7 (permalink) |
Member: 1149419 Status: Offline Sonork: NIL Thanks Meter: 58 | X2-01 not power after flash. MXKEY [MxKey Team HTI PLUS Flasher Interface 4], SN: C08067FA Using device: USB ROM and HTI, FW ver: 00.50, SN: 0100ADEA Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012) Processing MCU file: rm709__08.71.mcusw [BB5,XSR 1.6] size: 26.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... Waiting for USB ROM device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ACE961 CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000D683D507CCD16CA6B72C5E97485E5B CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ACE961 FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT MDM_KEYS (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35791504089894_CE RT.rpl). CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6F [] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 12.312 s Processing PPM file: rm709__08.71.ppm_mh1 [BB5,XSR 1.6] size: 6.53 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 6.547 s Processing CNT file: rm709__08.71.image_mh1_059D365 [BB5,XSR 1.6] size: 23.91 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 22.609 s Total time for flashing process(boot+erase+write) was 1 min 18.156 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1ACE961 Waiting for USB device removal ... Warning: Phone did not reboot to normal mode. [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) ! |
