Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 04-28-2012, 10:58   #1 (permalink)
Member: 713923
Help X1-01 Sim not valid with mxkey
This phone log :
MXKEY [FT SCR2000 0], SN: xxxxxxxxx
Using device: HTI, FW ver: 00.50, SN: xxxxxxxx
Connection status: OHCI:HUB:USB 2.00 (Full-speed)
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20766(30-03-2012), Library ver: 1.0.0.14016(30-03-2012)
Device synchronized.
CPU: XGOLD 110
Using embedded SBL from MCU.
Sending EBL Loader ...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.24
EBL version: Default_RAM_Bootloader
Set baud rate to: 921.60 Kbit/s
Flash ID: 0020 8804 - 23280001 [ST 58LR128U,128 Mbits]
CFI information:
Flash settings: 0/64, size: 0x01000000
2 Block regions:
127 x 0x00020000 = 0x00FE0000
4 x 0x00008000 = 0x00020000
EBL ready !
Phone type: RM-713
SW version: V 07.50 29-11-11 RM-713 (c) Nokia
Imei plain: 35976404473334-1
Product code: 059D8Q4
Cellular system: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: ME
Language Pack:
English,Bahasa Ind,,Chinese S,Chinese T
Imei net: 35976404473334
Provider: GSM Test Operator
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 0000000000040002
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
Old 04-28-2012, 11:06   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
bro. post selftest logs.
Old 04-28-2012, 13:50   #3 (permalink)
Member: 713923
this selftest logs:
Phone Type: RM-713
ID Test name Startup Result
42 RADIO Y passed
39 WARRANTY Y passed
33 SIM_LOCK Y passed
10 PPM_VALIDITY Y passed
43 LCD Y passed
80 KEY Y passed
81 PA Y passed
82 ADC1 Y passed
83 RTC_32KHZ Y passed
84 GPIO_LIGHT Y passed
85 HOOK_KEY Y passed
86 ACCESSORY Y passed
87 SIM_IF Y !no signal
88 SIM_INSERTED Y !no signal
90 FLASHCHK Y passed
94 SD_POWER Y passed
92 SIM2_IF Y !no signal
93 SIM2_INSERTED Y !no signal
91 SECURITY Y passed
Old 04-28-2012, 14:33   #4 (permalink)
Member: 262425
Sonork: 100.1617691
bro. test seems to be OK, try flashing may be good result.
Old 04-29-2012, 08:24   #5 (permalink)
Member: 713923
Problem solved...i downgrade to firmware v5.44
Phone type: RM-713
SW version: V 05.44 26-05-11 RM-713 (c) Nokia
Ppm Id: ME
Language Pack:
Counter: 0/3, 0/10
thanks......
Old 05-01-2012, 18:09   #6 (permalink)
gbluez's Avatar
Member: 73565
Good,
Please update your mobileex version as well mr.yudi
Old 08-15-2012, 16:03   #7 (permalink)
..::Rana Bilal::..'s Avatar
Member: 472378
Sonork: 100.1597506
Phone type: RM-713
Ppm Id: ME
Language Pack:
Counter: 0/3, 0/10
thanks......
how can u downgrade mean witch device r u use for it and how can
Old 08-16-2012, 05:30   #8 (permalink)
specta's Avatar
Member: 1149800
he used hti, xgold 110 can be upgraded & downgraded without any risk. have fun bro
br
Old 11-01-2012, 12:24   #9 (permalink)
rakib_sheak's Avatar
Member: 1201843
need help...............
Old 04-10-2013, 11:21   #10 (permalink)
nnarasimha's Avatar
Member: 1487169
Sonork: 1254
Yes is working me thx frend,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,
The Following User Says Thank You to nnarasimha For This Useful Post:
Page generated in 0.74051 seconds with 11 queries
