Old 01-02-2011, 10:41   #1 (permalink)
Member: 1313132
Thanks Meter: 88
Here is the best GPU to Unlock very faster
ATI Sapphire Radeon HD 5970 Toxic 4GB
Old 01-02-2011, 10:52   #2 (permalink)
Member: 456932
Thanks Meter: 53
whats the price of this card.
Old 01-02-2011, 11:37   #3 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
go here Sapphire Radeon HD 5970 4GB Toxic Review | bit-tech.net
Old 01-02-2011, 15:06   #4 (permalink)
Registered User
Member: 291029
Thanks Meter: 97
Fantastic man
Manufacturer: Sapphire
UK Price (as reviewed): £900+ (inc. VAT) MSRP
US Price (as reviewed): $1099 (exc.Tax) MSRP
Old 01-03-2011, 07:53   #5 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
Very very cheep he he he he
Old 01-03-2011, 08:04   #6 (permalink)
zullu2004's Avatar
Member: 146635
Sonork: 100.1651273
Thanks Meter: 261
course this is only the graphic card
you also need new mother board, new cpu, etc
Old 01-03-2011, 11:01   #7 (permalink)
Member: 733449
Sonork: 100.334100
Thanks Meter: 292
And waiting huge time also
Old 01-03-2011, 12:15   #8 (permalink)
celucables's Avatar
Member: 65115
Sonork: 100.71218
Thanks Meter: 72
VIDEO CARD HD5970 HIGHER !! for SL3 CALC
I found this version Card on My local Market,
(same product diferent version)
If somebody interested, let me know to
put in contact with the guy,
(he have just a few pieces on stock..)
Gino
[email protected]
Specifications
Mfr Part Number: HD597ACNB9
Chipset: Radeon HD5970
Engine Clock: 725 MHz
Video Memory: 2GB DDR5
Memory Clock: 4 GHz
Memory Interface: 512-bit
Bus: PCI-Express 2.0 x16
RAMDAC: 400 MHz
Max. Resolution: 2560 x 1600
Connectors: Dual DVI; DisplayPort
Stream Processors: 3200
Thermal: Fansink
Support Microsoft DirectX 11, Shader Model 5.0 and OpenGL 3.2
Support ATI Radeon CrossFireX Technology
Support ATI Radeon Stream Technology
Support ATI Radeon PowerPlay Technology
Support ATI Eyefinity Technology
Power Supply Requirement: 650 Watts one 6-pin and 8-pin power connectors
Package: Retail
ROHS Complaint
ATI Radeon? HD 5970
GO.
Technology takes a trip down the fast lane with the XFX ATI Radeon? 5970 graphics card. The fastest dual GPU-on-a-PCB card on the planet, this powerhouse also comes in a "I've-never-seen-that-kind-of-speed-before" Black Edition. Powered by two brutally fast GPUs and 3200 stream processors, the 5970 delivers shockingly fast frame rates and is supported by the most robust advanced feature set available today, including support for up to three displays with ATI Eyefinity technology. Created for the true performance enthusiast, the 5970 offers the ultimate in speed, performance, energy efficiency and support.
ATI Eyefinity Technology allows two or more display outputs operating simultaneously and cooperatively with one another. Support is available for Duplicated (Clone), Extended Monitor and Single Large Surface mode (SLS). SLS mode is capable of grouping multiple displays into a massive single large display for use with desktop workspace, video playback, with support for both windowed and full screen 3D applications.
ATI Eyefinity Requirements
Windows Vista and Windows 7 operating system (Eyefinity is not supported in Windows XP)
A graphics card with at least one native DisplayPort output
Display with native DisplayPort
and/or
Use of an certified active DisplayPort adapter is required to convert the DisplayPort output on the graphics card to an output compatible to the display when more than two displays are used in a multi-display configuration (available for purchase separately)
Now bundled with an XFX exclusive OverVolt Tool. Take charge of the GPU and memory voltages with an exclusive performance enhancing tool only available for use with the XFX HD 5970 Black Edition. With this tool, you can give your GPU performance an increase of up to 30%.* Product registration required to access this tool and the power to fine tune the voltage settings and unleash the performance limits.
*The HD 5970 Black Edition ships with default GPU and memory clocks set at 725 MHz and 4.0 GHz respectively. It's overclock performance will depend on the graphics card, other system components, and may also be affected by environmental conditions.
KEY FEATURES
2GB GDDR5 memory
ATI Eyefinity technology with support for up to three displays (1,3)
Window 7 support
ATI Sream technology (2)
Designed for DirectCompute 5.0 and OpenCL
Accelerated Video Transcoding (AVT) (2,4)
Compliant with DirectX® 11 and earlier revisions
Supports OpenGL 3.2
40 nm Process technology
ATI CrossFireX? multi-GPU support for highly scalable performance (5)
ATI Avivo? HD video and display technology (6,7)
Dynamic power management with ATI PowerPlay? technology (6)
Display Port, HDMI, 2xDL-DVI
PCI Express® 2.0 support
(1) To enable a third display you require one panel with a DisplayPort connector.
(2) Requires application support for ATI stream technology.
(3) ATI Eyefinity technology works with games that support non-standard aspect ratios which is required for spanning across three displays
(4) Digital rights management restrictions may apply.
(5) ATI CrossFireX? technology requires an ATI CrossFireX Ready motherboard, an ATI CrossFireX? Bridge Interconnect(s) and may require a specialized power supply.
(6) ATI PowerPlay?, ATI Avivo? and ATI Stream are technology platforms that include a broad set of capabilities offered by certain XFX Radeon? HD GPUs. Not all products have all features and full enablement of some capabilities and may require complementary products.
(7) HD capable display require
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.17546 seconds with 9 queries
