12-25-2011, 21:41 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: IN mobile's
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Hi guys plzz help me how to repair this phone NOkia 5800d Using device: HTI, FW ver: 00.50, SN: 0000B580 Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.0.0 , NTMP ver: 6.1.7601.17514 Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011) CMT Data : SYSTEM ASIC ID: 000000010000022600010006400C192101031103 [RAPIDO3G ver: 1.13] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 137000082C72005223F315EDA6D2E1164E1EDE8D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.34.0 revision: 2.0 size: 0x3B80 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 eBB5ProtocolType: NEW TransmissionMode: DDR&TX2 Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0121 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.5 Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.34.0 revision: 2.0 size: 0x8FE30 Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105 TransmissionMode: DDR&TX2 FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Processing MCU file: RM-356_40.0.005_prd.core.C00 [BB5,XSR 1.5] size: 545.68 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase skipped. Flash programming ... Programming completed in 0.002 s Processing PPM file: RM-356_40.0.005_prd.rofs2.V19 [BB5,XSR 1.5] size: 14.43 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase skipped. Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 39.859 s Processing PPM file: RM-356_40.0.005_C02_prd.rofs3.fpsx [BB5,XSR 1.5] size: 1.10 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase skipped. Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 3.105 s Processing CNT file: RM356_40.0.005_004_U206.uda.fpsx [BB5,XSR 1.5] size: 980.32 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase skipped. Flash programming ... Prog.status for Asic CMT ... NAND: OK Programming completed in 3.730 s Total time for flashing process(boot+erase+write) was 53.901 s i also try to flash it via usb but problem still same phone not enter test mode but when i press flash button status bar bar show this Phone entering charging mode for sec. And here is with other updated flash file . FUR: Adding Asic CMT as client OK CMT PAPUBKEYS HASH: 76A20187051C30162EE91C77AE5E6011F5F1BA61 Processing MCU file: RM-356_60.0.003_prd.core.C00 [BB5,XSR 1.5] size: 110.45 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 158.19 MB CMT FLASH,MuxOneNAND area [00040000-00082FFF] CMT FLASH,MuxOneNAND area [00083400-003FFFFF] CMT FLASH,MuxOneNAND area [00400000-007FFFFF] CMT FLASH,MuxOneNAND area [00800000-00D5FFFF] CMT FLASH,MuxOneNAND area [00D60000-09E5FFFF] Formating partition ... Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 76A20187 [RAP Certificate 106 v1] sent CMT SOS*UPDAPP block sent CMT SOS*ENO block sent CMT SOS*DSP0 block sent CMT SOS*ISASW block sent CMT SOS+CORE block sent CMT SOS+ROFS1 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 4 min 55.168 s Processing PPM file: RM-356_60.0.003_prd.rofs2.V19 [BB5,XSR 1.5] size: 14.62 MB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 31.87 MB CMT FLASH,MuxOneNAND area [07180000-0915FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS2 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 40.265 s Processing PPM file: RM-356_60.0.003_C03_prd.rofs3.fpsx [BB5,XSR 1.5] size: 703.60 KB Supported Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103 Erase size: 13 MB CMT FLASH,MuxOneNAND area [09160000-09E5FFFF] Prog.status for Asic CMT ... NAND: OK Flash programming ... CMT SOS+ROFS3 block sent Prog.status for Asic CMT ... NAND: OK Programming completed in 1.983 s Total time for flashing process(boot+erase+write) was 5 min 46.090 s Please help me |
12-25-2011, 22:13 | #2 (permalink) | |
Member: 771565 Status: Offline Sonork: 100.1656305 Thanks Meter: 145 | Quote:
12-25-2011, 22:23 | #4 (permalink) |
No Life Poster Join Date: Feb 2008 Location: Bosnia
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | nokia 5800d is rm428 latest version (RM-428) Major 51.2.007 v15 LTA rm-356 5800 not 5800d for 5800 (RM-356) Major 60.0.003 v17 flash in dead usb |
12-26-2011, 07:51 | #6 (permalink) | |
Thanks bro but where i can find 60.0.003 v17 i have latest files but but v17 is missing i also try to find in universal box files but there is no v17 other are there but no t v17 please help me | |
12-26-2011, 08:09 | #7 (permalink) | |
Connect phone on selected interface... Core version : 1.30 Rev : 1.1 Selected FlashSettings : Manual -> File : RM-356_60.0.001_026_000_U01.uda.fpsx not found! Check it! Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-356_60.0.003_prd.core.C00 PPM : RM-356_60.0.003_prd.rofs2.V19 PPM2 : RM-356_60.0.003_C02_prd.rofs3.fpsx Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... [BB5 FLASH]: Bootrom Ok! ASIC ID: 000000010000022600010006400C192101031103 CPU ID : RAPIDOv11 , Features : Dead-Test, USBRPL, WR/ER-USB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 137000082C72005223F315EDA6D2E1164E1EDE8D ASIC MODE ID: 00 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-356_60.0.003_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.core.C00 Total 510 [510/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] TIME : Write time : 00:00:34 MCU Write done ===Flashing [PPM]=== Erase : Processing RM-356_60.0.003_prd.rofs2.V19 Found 1 areas to erase Erasing area 0x07180000 - 0x0915FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_prd.rofs2.V19 Total 65 [65/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS2] TIME : Write time : 00:00:04 PPM Write done ===Flashing [PPM2]=== Erase : Processing RM-356_60.0.003_C02_prd.rofs3.fpsx Found 1 areas to erase Erasing area 0x09160000 - 0x09E5FFFF, NAND, CMT Result: 0000 TIME : Erase time : 00:00:00 Write : Processing RM-356_60.0.003_C02_prd.rofs3.fpsx Total 11 [11/0/0] blocks to write, writing... CMT : Writing Hash CERT [SOS+ROFS3] TIME : Write time : 00:00:00 PPM Write done ================= ADL : End flashing ADL : Finalize... Flashing done! Total flash time : 00:00:40 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Elapsed: 00:02:30 Connect phone on selected interface... Core version : 1.30 Rev : 1.1 I'm unable to find v17 but here is v19 flashing logo After full flash phone show some lines on display for some time but not come in test or local mode | |
12-26-2011, 10:50 | #10 (permalink) | |
No Life Poster Join Date: Sep 2009
Member: 1128573 Status: Offline Thanks Meter: 242 | Quote:
thanks, br, N.B.- phone can flash complete, but not come local or test mode. phone only vibrator. this is not flash file or flash problem. check others. | |
12-26-2011, 12:33 | #11 (permalink) | |
other means hardware phone was okey before flashing phone was come in slow working problem . so i decide to flash it and now its dead only vibrate | |
12-26-2011, 14:09 | #12 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
just one question bro, what tools r u using? i've never seen log like this do u post in the right section bro? have u done bb5quickfix?? if not, then do it. or u can try this: back up npc/rpl, then use erase/eno file, then reflash with latest version, use search button for the file bro. and also i have read somewhere here about downgrade to version 20.0.012 will work, again try search button good luck bro br Last edited by specta; 12-26-2011 at 14:14. | |
12-26-2011, 16:18 | #13 (permalink) | |
Insane Poster Join Date: Jul 2007 Location: Indonesia
Member: 554727 Status: Offline Thanks Meter: 4 | Quote:
If you already save RPL and simlock. You can perform a full erase, flash mcu only, if the damage on the phone hardware will not be local mode. If the software unit will damage local mode, write rpl, write simlock, repair SD, and so on. This process has the risk of losing simlock if you do not save it. | |
12-26-2011, 18:00 | #14 (permalink) | |
Member: 698071 Status: Offline Sonork: 100.1622915 Thanks Meter: 283 | Quote:
