Old 10-11-2012, 14:08   #1 (permalink)
F Alam86's Avatar
Member: 1134306
Thanks Meter: 132
Question Hi i need Nokia C2-01 RM-721 flash file
Hi i need Nokia C2-01 RM-721 flash file v 11.21 with product code 059D5M3 i hv try with navifirm & Mx key download but these files r not there plz healp me
Old 10-11-2012, 16:18   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Your Latest Version with Phone Product Code is 11.20,
So don't try to Flash with 11.21 & Download Version 11.20 for the same will work for you.
BR,
ZUBER
Old 10-11-2012, 17:16   #3 (permalink)
F Alam86's Avatar
Member: 1134306
Thanks Meter: 132
Originally Posted by .::ZUBER::. View Post
Your Latest Version with Phone Product Code is 11.20, So don't try to Flash with 11.21 & Download Version 11.20 for the same will work for you. BR, ZUBER
Sir it was allready 11.21 flashed the phone so i need 11.21 with this product code plz healp me
Old 10-11-2012, 17:33   #4 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,263
Is Phone working at this Moment?
If OK then Backup RPL,
Read & save full PM.
Select Firmware 11.21 from Drop Down Menu,
Double Click on PPM & change it with Original Product Code file of 11.20,
Now Flash it will work for you.
Do on your own Risk.
BR,
ZUBER
Old 10-12-2012, 16:15   #5 (permalink)
F Alam86's Avatar
Member: 1134306
Thanks Meter: 132
Is Phone working at this Moment? If OK then Backup RPL, Read & save full PM. Select Firmware 11.21 from Drop Down Menu, Double Click on PPM & change it with Original Product Code file of 11.20, Now Flash it will work for you. Do on your own Risk. BR, ZUBER
Thanks my problem solved with this method thanks alot
Page generated in 0.22089 seconds with 7 queries
