Crazy Poster
Member: 1764819
Sonork: 100.1641678 Thanks Meter: 7 | Nokia 700 flashing done Nokia 700 flashing done Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 4], SN: xxxxxxxxx
Using device: USB ROM and HTI, FW ver: 00.50, SN: 0xxxxxxx
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21064(15-06-2012), Library ver: 1.0.0.14102(15-06-2012)
Processing MCU file: RM-670_112.010.1404_79u_prd.core.fpsx
[BB5,XSR 1.6] size: 128.73 MB
Supported Ids: 0003192103002007, 000C192103002007, 4003192103002007, 400C192103002007, 0003192103012007, 000C192103012007, 0003192103002107, 000C192103002107, 000C192103012107, 000C192103012107, 0003192103022107, 000C192103022107, 0003192103032108, 000C192103032108, 4003192103032108, 400C192103032108, 000C192103042108, 0003192103042108, 400C192103042108, 4003192103042108
Make sure USB cable, Battery and charger are removed from device.
Insert USB cable, Battery back to device(make sure to have fully charged battery).
Insert Charger or Press phone's power button(if flashing doesnt start automatically)
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x]
CMT EM0 ID: 00000C35
CMT EM1 ID: 00000C30
CMT PUBLIC ID: 6E520000FFFB7C401EE8DDA4FCA4D127A75B4CE2
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706
CMT ROM ID: 2CAC45E23BC33C8B
Loading CMT secondary boot code
SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT
Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0060 - 0000 0032 [Samsung LH28F800BG] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Loading CMT update server data
Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 2xxxxxxx
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT VARIANT (0x0 bytes).
Reading CMT CCC (0x1CC bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Reading CMT MDM_KEYS (0x0 bytes).
Reading CMT PARTNERC (0x0 bytes).
NPC_DATA saved OK
CCC_DATA saved OK
HWC_DATA saved OK
RPL saved to "D:\3.5\data\backup\BB5_35702304597655_CERT.rp l"
CMT PAPUBKEYS HASH: BD43E84B21F8AC7B9C66EA939355891E2A08044A
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 621.56 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [010C0000-170FFFFF]
CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT SOS+DECOMP block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: BD43E84B [] sent
CMT GENIO_INIT block sent
CMT SOS+IVE3A block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
Programming completed in 26.125 s
Processing PPM file: RM-670_112.010.1404_10.01_MEA_A_79u_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 41.54 MB
Erase size: 100 MB
CMT FLASH,MuxOneNAND area [0D1C0000-135BFFFF]
CMT SOS+ROFS2 block sent
Programming completed in 8.312 s
Processing PPM file: RM-670_112.010.1404_02.01_truetest_79u_prd.rofs3.fpsx
[BB5,XSR 1.6] size: 384.08 KB
Erase size: 59.41 MB
CMT FLASH,MuxOneNAND area [01678000-0169FFFF]
CMT FLASH,MuxOneNAND area [135C0000-170FFFFF]
CMT SOS+ROFS3 block sent
CMT SOS+IVE3B block sent
Programming completed in 0.094 s
Processing CNT file: RM-670_112.010.1404_U03.01_79u.uda.fpsx
[BB5,XSR 1.6] size: 151.79 MB
Erase size: 368 MB
CMT FLASH,MuxOneNAND area [17100000-2E0FFFFF]
Programming completed in 35.172 s
Total time for flashing process(boot+erase+write) was 1 min 29.750 s
Waiting for device boot up ...
Device connected: nmwcdc\Nokia 700 USB Phonet, PORT_ID: 7CE055A
Verifying communication to device OK.
Phone type: RM-670 (Nokia 700)
SW version: V 79u_sr2_12w09_4 29-03-12 RM-670 (c) Nokia
ApeCoreSw: 112.010.1404
Imei plain: 35xxxxxxxxxxxxxxx3
Product code: 059G2P7
Battery voltage: 3833 mV, current: 216 mA
Language Pack:
- not available.
SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK)
warning: avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 35xxxxxxxxxxxxxxx3
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN
