02-06-2010, 17:50 | #1 (permalink) |
Freak Poster Join Date: Apr 2005 Location: lahore Age: 43
Member: 139020 Status: Offline Thanks Meter: 15 | how can i solve this problem 3110c SIMLOCK_DATA corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.21 05-11-08 RM-237 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 5.265 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_354206034241443_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 354206034241443 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF RAP Data : SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] EM0 ID: 00000232 EM1 ID: 00000353 PUBLIC ID: 286000172FD87E5638AFC4442C417E8CFBDC34BF ASIC MODE ID: 00 ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8981 - 0000 0000 [Intel NU48F256,256 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: C0E691EA16A7593A9BB28832D7312A39F7ED668D PA_SIMLOCK: PA_SL SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! aftter doing repair Splock SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! Using device: J.A.F, FW ver: 01.B1 Library version: 1.0.0.11985, Date: 03-02-2010 Product: V 07.21 05-11-08 RM-237 (c) Nokia. SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1] ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1 ROM ID: 191EC665DFAAF68F Sending SecondaryBoot ...OK Sending PreLoader ...OK Sending CustomLoader ...OK Calculating SIMLOCK using security server ... Connecting to server[main.mxkey.biz] ... Connecting to server[main.mxkey.biz] ...OK, secure login ... Completed in 14.093 s RPL saved to "C:\mobileEx\3.3\data\backup\BB5_RM-237_354206034241443_SIM.RPL" Updating SIMLOCK...error 0x1 Reading Simlock info ... Imei net: 354206034241443 Version: SIMLOCK SERVER VERSION 63 Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-06-2010, 21:01 | #3 (permalink) |
Junior Member Join Date: Nov 2009 Location: in my j.a.f box Age: 38
Member: 1172368 Status: Offline Thanks Meter: 6 | A final solution to the problem ( "SECURITY_TEST failed!"), A server after you update 1/backup rpl 2/erase flash with erase file 3/flash phone with last flash (updat flash files) 4/reset npc take are the imei phone will be 123....... 5/make repair sd 6/write good pm whith super sd auth 7/ go to the backup rpl and write tow fild only [CERT_PROG_DATA_OUT_CMT] PRODUCTCODE=0548252 PSN=SAM715419 HWID=6019 NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533393239350000000000 NPC_DATA_2=0000000000000000000000008343E094133FB34 733BA3B00646F72420000000015D00004F86D0254 NPC_DATA_3=993B8A5575DDE33F61271BF75E8D0D504A0902E 261268C14FCD8A2C9093523BC08B29FC2A70A4CF5 NPC_DATA_4=C5D28C7A013690617623EAB7000000000000000 000000000000000000200000047534D0000000000 NPC_DATA_5=3325190632277731FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF42545F4944000000 NPC_DATA_6=527AAD011F00000000000000000000000000000 0000000000000000000000000AEDB09F99D6E0BE4 NPC_DATA_7=34FE5501291C21811678030DA507E6BEB5C747B 51C3344AD9B0BA476149D955EBCBF48C27D7F238B NPC_DATA_8=7E609DF67F0305DA97882F9F54AAA83778C645A 2B3D25508A9881F510782B60B1DC321BE93E767E9 NPC_DATA_9=34BF634260B71733E822679E617CA4318570EC3 BDFC2F3789633B7307432E4D888180B4AEB069C2A VARIANT_DATA_1=357043A5020041500100000030353339323 935430033E093DC71CE448E005600D826990000000000 VARIANT_DATA_2=08000000220000000000000000000000AB9 68C43BFFF7AF7276138E0D251449807EBE517BD6A92CA VARIANT_DATA_3=025FC6132B207237945BC457C122271FCD7 A00EB2119FEAF7A8FCBED4D2C7BCA903DCF8308ED1403 VARIANT_DATA_4=3E2C060B117A0A8F0DE44E1BC878E1152FB 4646F10CE90BF72F7FB95922B3C8FDC261F1C502E1E20 VARIANT_DATA_5=7EB9CCE7541D6B6ACCD98FBC7217F210776 F0366FB887423 the problem will be solved big thank`s manole |
How can i solve this problem | Momo_Gsm | SETool2 | 4 | 11-02-2008 08:28 |
how can i solve this problem? | ..::Mobile Smoker::.. | HWK | 1 | 07-10-2008 15:14 |
how can i solve this problem | avn | Infinity-Box | 5 | 06-09-2008 21:12 |
how can i solve this problem | Zein Zozza | Cruiser Suite | 3 | 02-13-2006 00:24 |
how can I solve this problem | buddhabar | Nokia Digital Core Technology 4 ( DCT-4 ) | 2 | 01-29-2006 17:51 |
