Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-25-2010, 08:48   #1 (permalink)
powerplay83's Avatar
Member: 753732
How can i solve Security Test Fail, after unlock by Mx-key
i had unlocked Nokia 6760 RM-573 by Mx-key, after unlocking show me Security test fail, how can i solve it by mx-key i dont found any PM in the support?
 Phone Type: RM-573 (Nokia 6760s-1)
SW Version: V 09w17.03.38 09-09-09 RM-573 (c) Nokia
Imei plain: 35520303240962-6
Product Code: 0592888
Language Pack:
- not available.
SIMLOCK seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST failed!
Imei net: 355203032409626
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 03-25-2010, 08:54   #2 (permalink)
Member: 303373
Sonork: 100.1584377
Language Pack:
- not available.
Counter: 0/3, 0/10
Do sx4 not (super sd auth) n write pm (filed 1 n 309).If not solved than read rpl n post here.
Old 03-25-2010, 08:56   #3 (permalink)
jaleelkuttikkar's Avatar
Member: 591669
Sonork: 110011
.......Or check this way
[MXKEY - SERVER UPDATE] Solved "SECURITY_TEST failed!" after SD repair
Old 03-25-2010, 08:59   #4 (permalink)
Member: 303373
Sonork: 100.1584377
Originally Posted by jaleelkuttikkar View Post
That is not after sd repair.This is after unlock.
Old 03-25-2010, 09:00   #5 (permalink)
Member: 753732
as i said i dont have any PM of this Type 6760s RM-573 i searched in the forum but cant find any PM. can you upload this PM?
Old 03-25-2010, 09:32   #6 (permalink)
Member: 303373
Sonork: 100.1584377
I also didnt find any pm for this phone.If u can collect any ok phone than can read from that phone.
Still im finding.If i will success must post here.
Old 03-25-2010, 09:33   #7 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
.::Solution for::. Security Test Fail .: HERE :.
Old 03-25-2010, 09:38   #8 (permalink)
kkvachhani's Avatar
Member: 469011
Arrow this is solution
just write good pm with pmm authority
Old 03-25-2010, 10:45   #9 (permalink)
Member: 753732
Originally Posted by rakesh15 View Post
i know how to do this, problem is i dont have PM for 6760s RM-573...
Old 03-25-2010, 14:39   #10 (permalink)
Member: 753732
OK i found PM here:
6760s RM573 PM FILE NEED
Now my phone is OK.
thanks all.
The Following User Says Thank You to powerplay83 For This Useful Post:
nokia n76 sucussfully phonestartup failure solved .security test fail solved manish_jain MXKEY Nokia Flasher and Unlocker (by Alim Hape) 7 02-14-2011 05:55
mxkey can't solve security-test failed. mobilezone1997 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 11-08-2010 13:53
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 10:19
n97 can unlock by mx-key ? keongkeong83 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-16-2010 14:24
Can we expect new security like n96,95 unlocking with MX-KEY sairat MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-21-2009 10:09
Page generated in 0.32291 seconds with 11 queries
