Old 01-28-2010, 10:16   #1 (permalink)
Member: 429744
Thanks Meter: 93
How can i write 66oo rpl
I AM WRITE RPL HE IS SHOW THIS LOGS
ASIC ID: 0x1081 [UPP_WD2 ver: 3.1]
SecondaryBoot: w3_2nd.fia [WD2 BT2] version: 4.76.0 revision: 0.7 size: 0x10D8
Supported Ids: 1080, 1081
FlashID0: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 00000000-007FFFFF
FlashID1: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 02000000-027FFFFF
FlashID2: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 04000000-047FFFFF
FlashID3: 0001 277E [AMD S29NS064J,64 Mbits] page size: 64 K type: NOR area: 06000000-067FFFFF
ExtBUSC: C600 00EA 7501 00EA 7801 00EA 7B01 00EA
Algorithm: w3_amd.fia [WD2 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x7F50
Performing Flash Authentication ...OK
UEM ID: 005A7BD4:2984DA7E
ASIC type: 5
UEM Imei: 6C6127E0B50346
Invalid uem checksum, UEM might be damaged !
Connecting to server ...OK, Login ...
Hello C08034C1, you have 1000 credits left.
Invalid DATA1 length, expected: 80 chars.
Old 01-28-2010, 12:05   #2 (permalink)
Member: 547967
Thanks Meter: 653
ASIC type: 5
Hello
bro ur Phone UEM is corrupted and can't solve by RPL only also u should replace this UEM with an Empty UEM and then write RPL in it Only RPL cannot solve ur problem.
Thanxs
The Following User Says Thank You to mujahid_ali For This Useful Post:
How can I write 1100 rpl file to login mx key? caremobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 09-09-2009 16:50
can i write bb5 rpl using P-Key and Tornado Box??? ufs_ternoda Nokia Base Band 5 ( BB-5 ) 2 09-08-2007 04:21
How can i write eprom by Geoflasher??? proxy_gsm Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 02-09-2004 12:44
How can I write original eep in c55? aZaRiaS E-Gold Based Phones 1 05-27-2003 15:37
Page generated in 0.17516 seconds with 10 queries
