06-02-2013, 09:51 | #1 (permalink) |
No Life Poster Join Date: Jan 2011 Location: united arab emirates (uae)
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | how can solve it??? SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35523203439855-2 Product code: 0571584 Battery voltage: 4864 mV, current: 14 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF0A021001, ver: XXX.XXX warning: DCC corrupted ! SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
06-02-2013, 10:34 | #2 (permalink) |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. Phone is SL3 & it's Bricked now, You can only solve it, if Backup present in your PC for this Phone, If no Backup, then only choice is to return Phone to Owner, Bcoz, Factory RPL not affordable for this cheap Phone. BR, ZUBER |
The Following User Says Thank You to .::ZUBER::. For This Useful Post: |
06-02-2013, 11:24 | #3 (permalink) | |
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | Quote:
Version from phone: 07.97 Version from file: 07.98 MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C0880C6B Using device: HTI, FW ver: 00.50, SN: 01010940 Connection status: UHCI:HUB:USB 2.00 (Full-speed) Driver: WinUSB, ver: 3.5.1.0 Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14397(09-05-2013) RPL backup already exist (C:\mobileEx\3.5\data\backup\BB5_35523203439855_BA CK.rpl). CMT Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0] EM0 ID: 00000295 EM1 ID: 00000B22 PUBLIC ID: 03700119569D7D56E5C8635AF5D49B0EECC571E3 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 eBB5ProtocolType: OLD Storage0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: FLASH,NOR, asic:CMT Storage content: 0000 0000 0000 0000 0000 0000 0000 0000 Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT TransmissionMode: 16Bit Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.50.0 revision: 0.0 size: 0x23010 Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 CMT PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 TransmissionMode: DDR&TX2 Processing MCU file: rm495__07.98.mcusw [BB5,BB5 ALGORITHM] size: 18.20 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Storing certificate [NPC, VARIANT, R&D, CCC, HWC] ...OK Erase size: 21 MB CMT FLASH,NOR area [00000000-000006BF] CMT FLASH,NOR area [000006C0-0001FFFF] CMT FLASH,NOR area [00040000-000BFFFF] CMT FLASH,NOR area [000C0000-0013FFFF] CMT FLASH,NOR area [00140000-0137FFFF] CMT FLASH,NOR area [01380000-0151FFFF] erased in 1 min 23.188 s Prog.status for Asic CMT ... NOR: OK Flash programming ... CMT NOLO block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 0C917F11 [RAP Certificate 164 v.1] sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent Prog.status for Asic CMT ... NOR: OK Programming completed in 1 min 11.641 s Processing PPM file: rm495__07.98.ppm_x [BB5,BB5 ALGORITHM] size: 7.72 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 8.62 MB CMT FLASH,NOR area [01520000-01DBFFFF] erased in 33.188 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 28.329 s Processing CNT file: rm495__07.98.image_x_blu [BB5,BB5 ALGORITHM] page size: 128 K size: 13.02 MB Supported Ids: 010C192101013000, 0103192101003000, 0303192101033000, 030C192101033000 Erase size: 34 MB CMT FLASH,NOR area [01DC0000-0215FFFF] CMT FLASH,NOR area [02160000-03FBFFFF] erased in 2 min 57.830 s Prog.status for Asic CMT ... NOR: OK Flash programming ... Prog.status for Asic CMT ... NOR: OK Programming completed in 47.688 s Total time for flashing process(boot+erase+write) was 7 min 28.131 s Phone type: RM-495 (Nokia 5130c-2) SW version: V 07.97 13-09-10 RM-495 (c) Nokia Imei plain: 35523203439855-2 Product code: 0571584 Battery voltage: 4540 mV, current: 45 mA Language Pack: - not available. SLPA ver[1]: PA_SL (15 digit NCK) Camera config: NIMMIIIIRRFF0A021001, ver: 002.007 SIMLOCK invalid! SUPERDONGLE_KEY[MX] seems to be valid SIMLOCK_TEST failed! SECURITY_TEST passed SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! | |
06-02-2013, 11:36 | #4 (permalink) |
Member: 1495471 Status: Offline Sonork: 1603910:abubablu Thanks Meter: 1,582 | when i make backup its show .... PUBLIC ID: 03700119569D7D56E5C8635AF5D49B0EECC571E3 PRIVATE ID: D99AB5D785A8E602701F3B84F116E2269A897B1C Updating SIMLOCK ...error 0x1 Reading Simlock info ... SIMLOCK_DATA corrupted! SIMLOCK_DATA corrupted! |
06-02-2013, 12:16 | #5 (permalink) |
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Bro. This Backup is from Latest operations, Did this Phone arrived to you before & you have taken Backup, I think no, your Backup not containing Simlock or may be Corrupted, It will not work for you, so better return this Phone. BR, ZUBER |
