-   MXKEY Nokia Flasher and Unlocker (by Alim Hape) (http://forum.gsmhosting.com/vbb/f550/)
-   -   How Enter SL3 Unlock Code thru FBUS (SOLVED) (http://forum.gsmhosting.com/vbb/f550/how-enter-sl3-unlock-code-thru-fbus-solved-1334214/)
xerraco 08-24-2011 06:50
I find it hard to enter unlock codes thru FBUS using HTI MX Key, how to do it.
TY!
P.S. Ive enter code manually: Code Error
Br,
xerraco
xerraco 08-24-2011 11:03
Nobody knows I think! or just nobody answers.
MYUNLOCKING 08-24-2011 11:13
did you reset counters first?
xerraco 08-24-2011 11:31
Yes! Always 0/3 0/10 manual and using FBUS ;UB, ATF.
If i encounter wrong code w/c in keypad result in 1/3 & FBUS 1/10 I reset it using ATF to make it 0/3 0/10.
By the Way how to enter Code using MX Key bacause I cant seems to know how.
SPUnlock_SK 08-24-2011 15:01
acoording your desciption your NCK code will be wrong
anyway counter reset is also inside of MXKEY SW,, you can send NCK to phone by SL3logger (available in latest release)
CHAUDHRAY ARSHAD 08-24-2011 15:06
i just put other day with cylone box on x6 working perfect but y we we can put with mxkey
xerraco 08-25-2011 07:41
How can I send code to phone, if my Reseller gave me on code in .txt file.
SPUnlock_SK 08-25-2011 17:14
are you sure it's NCK?
it can be only MASTER SP CODE, from MASTER SP CODE you need to calculate NCK
post here content of TXT file
mrunlock198 08-25-2011 17:37
i I have the same problem here I leave the txt
353782040003531_COD.txt - 4shared.com - document sharing - download
SPUnlock_SK 08-25-2011 17:54
#pw+ 434995309795165 +7 #
here is level 1 code
#pw+ 522378802019251 +1 #
mrunlock198 08-25-2011 17:57
friend but I'll put the code and I get error code!!!!!
delux_gsm 08-25-2011 17:58
use infinity best dongel and slect level 1
ur problem solve 100%
br
delux_gsm
SPUnlock_SK 08-25-2011 17:58
did you check you counter status?
you can send NCK by cable, or reset counter in MXKEY SW
//edit
check my previous post, I added L1 code also
xerraco 08-27-2011 11:52
All Ok Now, Reseller send me .cod filehttp://img23.imageshack.us/img23/789...usunlocked.jpg
Thanks for all those who help!
Br,
xerraco
Page generated in 0.25956 seconds with 5 queries
