03-06-2010, 15:51 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Algeria Age: 46
Member: 78657 Status: Offline Thanks Meter: 71 | how to fix 1110i imei Code: Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010) ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008B206A:2984DA60 ASIC type: 2 UEM Imei: 35394501777995 Flash Imei: 35507500210212 MasterCode: 3254670630 Invalid imei checksum ! Phone Type: RH-93 SW Version: V 6.40 12-01-07 RH-93 (c) NMP Imei plain: ??????????????-? Product Code: 0532991 Cellular System: GSM ASIC ID: 0x2201, type: 2 Ppm Id: IA Language Pack: English,Arabic,Farsi,French,Urdu TimeStamp: 2007-12-11T13:41:20Z SW Version: 7.02 Variant Version: 001 ProductProfile: RH93_0532991_7.02_001.spr Simlock: 0532991_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: FFFFFFFFFFFFFF Version: Counter: 0/3, 0/10 CONFIG_DATA: 00000000000EFFB8 PROFILE_BITS: 0003562036013430 SIMLOCK_DATA corrupted! |
03-06-2010, 16:20 | #3 (permalink) |
Member: 78657 Status: Offline Thanks Meter: 71 | after rebuild imei second problem Code: Imei net: 35394501777995 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED Updating SIMLOCK ...Error 1 PhoneType:RH-93 SwVersion: V 7.02 10-12-07 RH-93 (c) NMP MCU file: rh93_07.020 Trying to find patch position ...OK, case id: 1 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008B206A:2984DA60 Area [01140000-0115FFFF] erased in 0.797 s Programming ... Programming completed. Updating SIMLOCK ...Error 0x16 ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 008B206A:2984DA60 Area [01140000-0115FFFF] erased in 0.797 s Programming ... Programming completed. Imei net: 35394501777995 Version: Counter: 0/3, 0/10 CONFIG_DATA: FFFFFFFFFFFFFFFF PROFILE_BITS: 0000000000010000 BLOCK 1: 1.CORRUPTED |
How to fix No IMEI, Repair Needed , Ziphone bricks, Dead phones | Amir-SkillZ | iPhone 2 / iPhone 3G / iPhone 3GS | 4 | 01-08-2009 00:38 |
how to fix bb5 imei@123456-78-901234 | ikhlaq | Universalbox | 7 | 06-18-2007 12:59 |
help... how to fix a ?????? imei. | fullbar88888 | Universalbox | 3 | 09-26-2006 01:14 |
How to fix C35 IMEI with ZeeSiemensG3 | TriMesh | x1x to x45/x50 | 29 | 01-06-2002 11:28 |
