Old 07-14-2010, 10:14   #1 (permalink)
Member: 238280
Thanks Meter: 12
how to fix this SECURITY_TEST failed!
IMLOCK seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
The Following User Says Thank You to adelzouaghi For This Useful Post:
Old 07-14-2010, 10:16   #2 (permalink)
Afghanboy's Avatar
Member: 1087322
Thanks Meter: 173
play the backup on it or on it after a clean pm
Old 07-14-2010, 10:17   #3 (permalink)
dArk_shAdE's Avatar
Member: 943187
Thanks Meter: 584
sir try to supersd auth..den load pm file or write pm file....
Old 07-14-2010, 10:40   #4 (permalink)
Member: 238280
Thanks Meter: 12
anning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.107.106.159
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Wrong response to SD verify request
Old 07-14-2010, 10:42   #5 (permalink)
khm050's Avatar
Member: 133201
Thanks Meter: 74
1 pm auth then write pm
if no success
2 superdongle auth then write pm
if no success
3 make backup and then got to imei then imei rebuild here u press recover cert 10000000000000000000000% u'll get success
Old 07-14-2010, 14:49   #6 (permalink)
Member: 238280
Thanks Meter: 12
not done
Old 07-14-2010, 14:54   #7 (permalink)
Member: 902108
Sonork: jhon_gate
Thanks Meter: 11
try it repair sd,, and .try pm auth -write pm , done
Old 07-14-2010, 14:57   #8 (permalink)
Member: 238280
Thanks Meter: 12
i try this repair sd ok
pm auth canning local SX4 Card ...
No SX4 Card found.
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.201.33.158
Old 07-14-2010, 15:01   #9 (permalink)
chimed09's Avatar
Member: 479816
Thanks Meter: 851
Arrow
No SX4 Card found.
with SX4 write pm file 1 and 309...
Old 07-14-2010, 15:07   #10 (permalink)
Member: 59185
Sonork: 100.1593175
Thanks Meter: 4,911
a good info with detailed explanation can be found here .
http://forum.gsmhosting.com/vbb/f550...ution-1044092/
Old 07-14-2010, 15:12   #11 (permalink)
Member: 265104
Sonork: 100.1609402
Thanks Meter: 88
right whit out npc rpl ur problem solved..
Old 07-14-2010, 16:56   #12 (permalink)
Member: 238280
Thanks Meter: 12
how to do it explaine plz
Old 07-15-2010, 09:59   #13 (permalink)
Member: 238280
Thanks Meter: 12
i do this but no scucsses
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8336(03-05-2010), 1.0.0.12955(03-05-2010)
Product: V 06wk41v41 18-09-07 RM-320 (c) Nokia
Using cached productData[138001023F8300583B72AD4C1D0A1B820CC65423] ...
Authenticating to SUPERDONGLE using security server ...
Bad phones ack on step1, probably SUPERDONGLE_KEY corrupted !
SERVER->Served by MXKEY - BLADE X at host4, agent version 1.1 revision 0.1
Scanning local SX4 Card ...
No SX4 Card found.
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 41.201.40.230
SUPERDONGLE get challenge failed !
No SX4 Card found.
Old 07-15-2010, 10:03   #14 (permalink)
Member: 238280
Thanks Meter: 12
pm whriting log
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 1 (4 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 5 (4 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 15 (4 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 27 (4 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Section: 2
- Key: 0, size 440 bytes written.
Section: 4
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 9, size 5 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
- Key: 8, size 8 bytes written.
- Key: 9, size 16 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 bytes written.
- Key: 5, size 6 bytes written.
- Key: 6, size 1 bytes written.
- Key: 7, size 2 bytes written.
- Key: 8, size 2 bytes written.
- Key: 9, size 2 bytes written.
- Key: 10, size 2 bytes written.
- Key: 11, size 2 bytes written.
- Key: 12, size 1 bytes written.
- Key: 13, size 1 bytes written.
- Key: 14, size 1 bytes written.
- Key: 15, size 1 bytes written.
- Key: 16, size 1 bytes written.
- Key: 17, size 1 bytes written.
- Key: 18, size 1 bytes written.
- Key: 19, size 2 bytes written.
- Key: 20, size 2 bytes written.
- Key: 21, size 1 bytes written.
- Key: 22, size 1 bytes written.
- Key: 23, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 1 bytes written.
- Key: 30, size 1 bytes written.
- Key: 31, size 1 bytes written.
- Key: 32, size 1 bytes written.
- Key: 33, size 1 bytes written.
- Key: 34, size 1 bytes written.
- Key: 35, size 1 bytes written.
- Key: 36, size 1 bytes written.
- Key: 37, size 1 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 4 bytes written.
- Key: 45, size 4 bytes written.
- Key: 46, size 1 bytes written.
- Key: 47, size 16 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 20 bytes written.
- Key: 51, size 10 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 20 bytes written.
- Key: 54, size 10 bytes written.
- Key: 55, size 1 bytes written.
- Key: 56, size 1 bytes written.
- Key: 57, size 1 bytes written.
- Key: 58, size 1 bytes written.
- Key: 59, size 1 bytes written.
- Key: 60, size 1 bytes written.
- Key: 61, size 1 bytes written.
- Key: 62, size 1 bytes written.
- Key: 63, size 1 bytes written.
- Key: 64, size 1 bytes written.
- Key: 65, size 1 bytes written.
- Key: 66, size 32 bytes written.
- Key: 67, size 32 bytes written.
- Key: 68, size 2 bytes written.
- Key: 69, size 2 bytes written.
- Key: 70, size 2 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 2 bytes written.
- Key: 73, size 2 bytes written.
- Key: 74, size 2 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 2 bytes written.
- Key: 79, size 2 bytes written.
- Key: 80, size 2 bytes written.
- Key: 81, size 2 bytes written.
- Key: 82, size 2 bytes written.
- Key: 83, size 2 bytes written.
- Key: 84, size 2 bytes written.
- Key: 85, size 2 bytes written.
- Key: 86, size 2 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 2 bytes written.
- Key: 89, size 2 bytes written.
- Key: 90, size 2 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 2 bytes written.
- Key: 93, size 2 bytes written.
- Key: 94, size 2 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 2 bytes written.
- Key: 97, size 2 bytes written.
- Key: 98, size 2 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 2 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 2 bytes written.
- Key: 103, size 2 bytes written.
- Key: 104, size 2 bytes written.
- Key: 105, size 2 bytes written.
- Key: 106, size 2 bytes written.
- Key: 107, size 2 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 2 bytes written.
- Key: 110, size 2 bytes written.
- Key: 111, size 2 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 2 bytes written.
- Key: 114, size 2 bytes written.
- Key: 115, size 2 bytes written.
- Key: 116, size 4 bytes written.
- Key: 117, size 4 bytes written.
- Key: 118, size 1 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 4 bytes written.
Warning: failed to write 11 - 121 (4 bytes)
Warning: failed to write 11 - 122 (4 bytes)
Warning: failed to write 11 - 123 (16 bytes)
Warning: failed to write 11 - 124 (4 bytes)
Warning: failed to write 11 - 125 (2 bytes)
Warning: failed to write 11 - 126 (2 bytes)
Warning: failed to write 11 - 127 (1438 bytes)
Section: 12
Warning: failed to write 12 - 0 (102 bytes)
Section: 31
Warning: failed to write 31 - 4 (26 bytes)
Section: 44
Warning: failed to write 44 - 0 (1 bytes)
Section: 50
Warning: failed to write 50 - 0 (2 bytes)
Section: 54
Warning: failed to write 54 - 0 (2 bytes)
Section: 96
Warning: failed to write 96 - 0 (24 bytes)
Section: 107
Warning: failed to write 107 - 0 (21 bytes)
Warning: failed to write 107 - 1 (79 bytes)
Warning: failed to write 107 - 2 (79 bytes)
Warning: failed to write 107 - 3 (70 bytes)
Warning: failed to write 107 - 25 (132 bytes)
Warning: failed to write 107 - 26 (16 bytes)
Section: 117
Warning: failed to write 117 - 0 (4 bytes)
Warning: failed to write 117 - 1 (3 bytes)
Warning: failed to write 117 - 2 (6 bytes)
Warning: failed to write 117 - 3 (1 bytes)
Warning: failed to write 117 - 4 (9 bytes)
Warning: failed to write 117 - 5 (10 bytes)
Warning: failed to write 117 - 6 (8 bytes)
Warning: failed to write 117 - 13 (3 bytes)
Warning: failed to write 117 - 14 (3 bytes)
Warning: failed to write 117 - 19 (40 bytes)
Section: 120
- Key: 0, size 944 bytes written.
- Key: 1, size 80 bytes written.
- Key: 2, size 20 bytes written.
- Key: 3, size 112 bytes written.
Section: 122
- Key: 0, size 2 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 208
Section: 217
- Key: 0, size 32 bytes written.
Section: 239
- Key: 1, size 2785 bytes written.
Section: 291
- Key: 0, size 92 bytes written.
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Section: 313
- Key: 0, size 615 bytes written.
Section: 322
- Key: 0, size 1 bytes written.
Section: 329
- Key: 0, size 8392 bytes written.
Section: 334
Section: 341
Warning: failed to write 341 - 4 (4406 bytes)
Section: 354
Warning: failed to write 354 - 0 (3 bytes)
Section: 356
Warning: failed to write 356 - 0 (2 bytes)
Warning: failed to write 356 - 1 (8 bytes)
Completed in 36.933 s
Old 07-15-2010, 10:56   #15 (permalink)
Member: 238280
Thanks Meter: 12
rpl
BB5_35698301575096_BACK2.rpl
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.21817 seconds with 9 queries
