Old 07-12-2009, 18:30   #1 (permalink)
Member: 12302
Thanks Meter: 22
how to flash 7710 (ADL) with mx key
i have only flashed mcu 7710, flashing this handset i used normal fbsus cable for MCU & DKU2 for ADL flashing. when start flashing it shows Performing Flash Authentication ...[ADL] Pooling for Nokia ADL Flashing Engine ...
new hardware found P1666 usb flash USB. after flashing the mcu it shows [ADL] ADL Flashing Engine not found, Timeout.
i want to know where is located (path)the driver file. i am attaching the log. pls give me a solution sir.
Processing file: rm12pr40302.300
ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]
u_2nd.fia: [DCT4] version: 4.70.1 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0001 2A7E [AMD S29NS032J,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
m_amd.fia: [MX/ORCA ALGORITHM] version: 4.70.1 revision: 0.7 size: 0x8130
OK
UEM ID: 00CB2598:2984DA60
Programming MCU ...
rm12pr40302.300:
[DCT4,MX/ORCA ALGORITHM] size: 2.29 MB
Supported Ids: 1130, 1131, 2141, 2140, 2142
Area [01000000-0100FFFF] erased in 0.500 s
Area [01010000-0139FFFF] erased in 26.188 s
Area [013A0000-013EFFFF] erased in 2.312 s
Area [017A0000-017EFFFF] erased in 0.047 s
Flash programming ...
Programming completed in 14.703 s
File Processed in 53.453 s
Flashing completed in 57.141 s
Old 07-12-2009, 21:26   #2 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,775
when plugin USB driver
change folder to
C:\mobileEx\3.2\modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\flash\Adsp\
br,
The Following 2 Users Say Thank You to Andra For This Useful Post:
Old 08-18-2009, 14:03   #3 (permalink)
Member: 767451
Thanks Meter: 178
and me i have problem with this phone how to flash with jaf- mx-key hwk or griffin pls help any user i hope soon
Old 08-18-2009, 14:55   #4 (permalink)
rakesh15's Avatar
Member: 1019591
Sonork: 100.1592733
Thanks Meter: 634
first open mobileX conect to nokia usb rom and the tick to mcu ppm cnt select file and flash enjoy don have a file go to support its easy
The Following User Says Thank You to rakesh15 For This Useful Post:
Old 08-19-2009, 09:05   #5 (permalink)
Member: 767451
Thanks Meter: 178
-ok let me try and iwillgie you detail thnks for reply
Old 08-20-2009, 06:57   #6 (permalink)
Member: 509384
Thanks Meter: 12
Use usb + fbus !!!!!!!!!
how to unlock DCT4+ models with mx-key - like 2600c, 2630, 1680? Boshko_Alfa MXKEY Nokia Flasher and Unlocker (by Alim Hape) 8 03-05-2010 15:55
How to BlackBerry ph lock with mx key???HELP anw MXKEY Blackberry Flasher and Unlocker (by Alim Hape) 1 02-14-2010 17:44
How to unlock siemens A70 with mx key help me dey mobiles MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 12-26-2009 02:34
Need some help how to unlock nokia e71 with mx key richiricherd MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 11-03-2009 08:30
how to unlock 5800/N96 with Mx key? is it possible or not? malikzahidawan MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 08-08-2009 21:12
Page generated in 0.21395 seconds with 10 queries
