Old 02-04-2010, 17:28   #1 (permalink)
askaralikp's Avatar
Member: 690456
Sonork: 1587650
Thanks Meter: 117
Red face nkia 7210 not enugh memory
sir
i have one nokia 7210 . problem is muzic playear open time not enug memorry plz give one soltion plz
Old 02-04-2010, 18:37   #2 (permalink)
h_mobiles's Avatar
Member: 908729
Sonork: 100.1589748
Thanks Meter: 152
Flash with higher version
Old 02-04-2010, 19:38   #3 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
or format rom drive and drive c:
Old 02-04-2010, 19:39   #4 (permalink)
kaleem munir's Avatar
Member: 720201
Sonork: 100.0000000
Thanks Meter: 643
try to format your set with jaf,if not than flash with latest version
Old 02-04-2010, 21:19   #5 (permalink)
Member: 399172
Sonork: 100.1581353
Thanks Meter: 81
iv faced a same problem the one n safe way is just update ur frimware with latest version n same product code..it will work...n try to do via usb or usr nokia software updater ur problem will solved 10000000000%
Old 02-04-2010, 21:22   #6 (permalink)
Member: 197720
Thanks Meter: 24
flash with usb is 100% solution
Old 02-04-2010, 21:58   #7 (permalink)
sajidashraf's Avatar
Member: 501674
Sonork: THEIF OF HEART
Thanks Meter: 883
sir
i have one nokia 7210 . Problem is muzic playear open time not enug memorry plz give one soltion plz
first tick 128k then
simple flash with letest version
7210 supernova not enough memory rpssana Nokia Hardware & Hardware Repair 26 07-20-2012 07:36
7210s not enough memory X-TRA Universalbox 7 05-17-2010 12:41
7210s 5220 not enough memory solution is here amirsaishi Nokia Base Band 5 ( BB-5 ) 10 03-30-2010 14:12
7210c not enough memory prob not solve see log navnath randive MXKEY Nokia Flasher and Unlocker (by Alim Hape) 14 03-18-2010 15:46
nokia 7210 not enough memory pawank Nokia Base Band 5 ( BB-5 ) 3 11-28-2009 12:07
Page generated in 0.16136 seconds with 9 queries
