01-03-2012, 16:31 | #1 (permalink) |
Freak Poster Join Date: Aug 2009 Location: Bharat
Member: 1087883 Status: Offline Sonork: 100.1651719 Thanks Meter: 38 | How rebuild imei for DCT4 (ANSWERED) Easy Imei restore for DCT4 phones started. ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005701D1:2984DA60 ASIC type: 2 UEM Imei: 35767901905745 Flash Imei: Empty Invalid imei checksum ! Investigating flash imei ... Flash imei is empty, checking for RPL backup ... Phone backup is NULL, you need RPL to restore imei! ASIC ID: 0x2201 [UPP_2M ver: 2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 005701D1:2984DA60 Programming FLASH Imei ... FLASH programmed successfully. Imei restore succesfull ! if you were restoring from imei patched phone, you should reflash the firmware to remove SW patch. |
01-07-2012, 09:00 | #3 (permalink) |
Product Supporter Join Date: Mar 2011 Location: ..::INDIA::.. Andhra Pradesh Age: 41
Member: 1528548 Status: Offline Sonork: 100.1613286(Offline) Thanks Meter: 2,242 | press doselect job button. try this way your problem solve......post result |
The Following User Says Thank You to ..:: SONY ::.. For This Useful Post: |
needed pinout for carkit(N61xx) | mobileinfo | Nokia Hardware & Hardware Repair | 2 | 07-23-2013 02:41 |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
