Old 03-09-2011, 21:21   #1 (permalink)
Member: 138583
Thanks Meter: 120
How to repair this IMEI, IMEI PLAIN IS INVALID (ANSWERED)
ASIC ID: 0x2142 [UPP_8M ver: 4.2 or 4.3]
SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
FlashID0: 0020 882E [ST M58LR128GU,128 Mbits] page size: 128 K type: NOR area: 01000000-01FFFFFF
FlashID1: 0000 0001 [unused/removed]
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
Performing Flash Authentication ...OK
UEM ID: 001A77B5:2984DA60
ASIC type: 2
UEM Imei: 15135900782360
SERVER->Served by MXKEY - BLADE X at host2, agent version 1.1 revision 0.6
RPL saved to "D:\mobileEx\3.4\data\backup\RPL\15135900782360.RP L"
Programming FLASH Imei ...
FLASH programmed successfully.
Phone Type: RH-49 (Nokia 3220)
SW Version: V 05.10 07-09-05 RH-49 (c) Nokia.
Imei plain: ??????????????-?
Imei OTP: 15135900782360
Product Code: 0536421
Cellular System: GSM
ASIC ID: 0x2142, type: 2
Ppm Id: I
Language Pack:
- not available.
Imei plain is invalid !!!
Imei net: FFFFFFFFFFFFFF
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: D131291FEF243A66
PROFILE_BITS: E1955B4DF7A77B78
SIMLOCK_DATA corrupted!
I tried to repair it but still problem.... TIA
Old 03-10-2011, 03:36   #2 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
i'm sure that this imei is not phone's original imei. it has changed some how.
messy digits inside OTP, indicates damaged on it (UEM data2)
Old 03-10-2011, 03:59   #3 (permalink)
Member: 138583
Thanks Meter: 120
Ok thanks for check that! So, what I can do friend?
Old 03-10-2011, 04:18   #4 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,062
hi,
you will need to change new uem chip, and fill new imei. or,
you can also put a used uem chip, with already programmed otp.
just need to calculate it.
The Following User Says Thank You to gbluez For This Useful Post:
Old 03-10-2011, 17:32   #5 (permalink)
Member: 138583
Thanks Meter: 120
Hehehe, I think its best to return it to customer! But very thanks for the info about what 2 do
Old 03-24-2011, 17:17   #6 (permalink)
Member: 627460
How can I repair corrupt imei ( ie. ???????????????4). Thanks in advance.
Old 03-24-2011, 17:33   #7 (permalink)
net.tarik's Avatar
Member: 1316000
Sonork: 100.1624093
Thanks Meter: 348
in dct4 tab
imei & security/online logger press login
tik dc4 imei or dct4+imei and press do select job.
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Page generated in 0.17619 seconds with 9 queries
