Old 05-12-2010, 09:12   #1 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
How to Repair "Invalid UEM Data" NOkia 1200 (Solved)
help needed by mxkey team i have nokia 1200
phone is now showing contact service
please tell me how to repair uem data
i write pm and unlock phone but still on contact service
here is bus check log
USC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
Performing Flash Authentication ...OK
UEM ID: 00C6261AA3BDA66
ASIC type: 11
UEM Imei: 35351702051817
Flash Imei: 35351702051817
MasterCode: 4057345357
RPL saved to "C:\mobileEx\3.4\data\backup\35351702051817_127364 2721_BACK.rpl"
Phone Type: RH-99
SW Version: V 5.91 27-03-09 RH-99 (c) NMP
Imei plain: 35351702051817-7
Product Code: 0546861
Cellular System: GSM
ASIC ID: 0x2292, type: 11
Ppm Id: IA
Language Pack:
English,Arabic,Farsi,French,Urdu
Imei net: 35351702051817
Version: SIMLOCK SERVER
Provider: ALL Operator, Country: -
Counter: 0/3, 0/10
CONFIG_DATA: 0010100000000000
PROFILE_BITS: 000000000001000B
BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN
Invalid UEM Data, No RPL backup will be made for this phone.
The Following User Says Thank You to sahil00150 For This Useful Post:
Old 05-12-2010, 10:36   #2 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
Any solution waiting 4 answer
Old 05-12-2010, 10:39   #3 (permalink)
rico_deep's Avatar
Member: 159757
Thanks Meter: 461
just UNLOCK your PHONE
br.
Old 05-12-2010, 11:03   #4 (permalink)
rasheedc007's Avatar
Member: 1245320
Sonork: 100.1612126
Thanks Meter: 140
hardware problam..chek uem..........
Old 05-12-2010, 11:14   #5 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
Thanks 4 reply i already unlock the phone but still same problem
i think it uem problem any body tell me step by step procedure how to repair uem
i will be very thankfull 2 u
Old 05-12-2010, 11:22   #6 (permalink)
Member: 548888
contact service??? try to write pm file on phone
what did u do??? any details??
Old 05-12-2010, 11:24   #7 (permalink)
Member: 1286072
Thanks Meter: 50
Arrow
yes its uem problem
1 normal rehot uem
2 reboll uem
3 replace it
Old 05-12-2010, 11:26   #8 (permalink)
Member: 548888
can we see whats on the display on mxkey if you self test the phone
Old 05-12-2010, 11:44   #9 (permalink)
realtech's Avatar
Member: 1003310
Thanks Meter: 28
did u try reflashing with new version? if the problem still persists replace the uem hope tht u have full rpl backup
Old 05-12-2010, 12:12   #10 (permalink)
ABDULMANAN's Avatar
Member: 754324
Sonork: LOVE MOHAMMAD (S.A.W)
Thanks Meter: 500
ASIC type: 11
Phone Type: RH-99
Ppm Id: IA
Language Pack:
Counter: 0/3, 0/10
dont worry cant rpl backup by mx no problem in phone
bug in mx exe
Old 05-12-2010, 12:33   #11 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
Here is the detail what i do
1 bus check (Auto save rpl on bus check)
2 full erase
3 flash phone (version rh99_05.910, rh99_05.91ia, rh990_nai5.91ia)
4 write PM File
5 unlock phone
6 reset full factory default
After all phone still on contact service
and here is selftest report
[URL=http://www.4shared.com/photo/suU-FdUZ/Selftest.html]
after run all
Old 05-12-2010, 12:44   #12 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
2 full erase
4 write PM File
5 unlock phone
after run all
Old 05-12-2010, 13:48   #13 (permalink)
sahil00150's Avatar
Member: 624567
Thanks Meter: 256
Thanks brothers 4 replies it lcd problem changeing lcd worked now phone is working fine
Page generated in 0.19311 seconds with 8 queries
