Old 07-29-2009, 10:11   #1 (permalink)
Member: 749916
Sonork: 1647914
Thanks Meter: 43
how repair SIMLOCK_DATA corrupted!
Phone Type: RM-495 (Nokia 5130c-2)
SW Version: V 06.65 01-04-09 RM-495 (c) Nokia
Imei plain: 3541790348xxxx-x
Product Code: 0571584
VariantId: E
Language Pack:
- not available.
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
SIMLOCK_TEST failed!
SECURITY_TEST passed
Scanning local SX4 Card ...
No SX4 Card found.
Connecting to server ...MXKEY-SERVER v2.3 hello 117.200.2.240
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Error sendAck!
The Following User Says Thank You to kumar_pvj For This Useful Post:
Old 07-30-2009, 04:56   #2 (permalink)
pallumobile's Avatar
Member: 659890
Thanks Meter: 263
VariantId: E
Language Pack:
- not available.
SIMLOCK invalid!
No SX4 Card found.
Error sendAck!
U can resolve ur problem only by writing new rpl.
The Following 2 Users Say Thank You to pallumobile For This Useful Post:
Old 07-30-2009, 07:49   #3 (permalink)
Member: 554531
Thanks Meter: 85
Thumbs up here is ur solution
VariantId: E
Language Pack:
- not available.
SIMLOCK invalid!
No SX4 Card found.
Error sendAck!
no need to write rpl just follow link get the solution
SL DATA SOLUTION 100% TESTED BY ME ON 6500S TODAY.
The Following User Says Thank You to dilipnachna For This Useful Post:
Old 07-31-2009, 16:06   #4 (permalink)
Member: 404911
Thanks Meter: 33
brother dit you know...5130 is SL3...???????
i think SL3 no solution today....
The Following User Says Thank You to gadhoel For This Useful Post:
Old 07-31-2009, 19:09   #5 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 680
we r talking about sl3 phone
The Following User Says Thank You to ranagaurav For This Useful Post:
Old 03-04-2010, 12:24   #6 (permalink)
Member: 1008759
Sonork: shohaglkpur
Thanks Meter: 19
hellp me nokia 5130c contac sarvice Using device: J.A.F, FW ver: 01.B1
Library version: 1.0.0.7705(18-02-2010), 1.0.0.12217(18-02-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2010020206B77D5688B759F8195CA47365DC52E6
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
FlashID0: 0089 8982 - 0000 0000 [Intel NU48F512,512 Mbits] type: NOR,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
Algorithm: RAP3Gv3_algo_131.fg [BB5 ALGORITHM] version: 1.31.0 revision: 0.0 size: 0x297E0
Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0
Original Imei: 35422303905946
Original Product code: 0571593
Bluetooth ID: 0025CF26AA98
SW Version: V 07.91 29-10-09 RM-495 (c) Nokia
Imei plain: 35422303905946-4
Language Pack:
- not available.
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
The Following 2 Users Say Thank You to shohaglkpur For This Useful Post:
Old 03-04-2010, 12:28   #7 (permalink)
Member: 783537
Thanks Meter: 8
i got 3 5130c here with contact service i tried it with mx-key and it did not work... they say it can be repaired by RPL but its too costly until now i'm waiting for updates
The Following User Says Thank You to chelroms For This Useful Post:
Old 03-04-2010, 12:36   #8 (permalink)
Member: 55412
Thanks Meter: 20
forget cotly its prisless caz its unavailable.
ull have to wait much longer for this ...when the price of ur handsets will go down to rpl cost
The Following User Says Thank You to cellcare_gujrat For This Useful Post:
Old 03-04-2010, 12:58   #9 (permalink)
r-jcomm's Avatar
Member: 601913
Sonork: 100.1597350
Thanks Meter: 651
Cool 5130c contect service
VariantId: E
Language Pack:
- not available.
SIMLOCK invalid!
No SX4 Card found.
Error sendAck!
bro write full pm after that make sd repair then write pm 1 and 309
The Following User Says Thank You to r-jcomm For This Useful Post:
Old 03-04-2010, 13:18   #10 (permalink)
Member: 775587
Thanks Meter: 26
contact hasnain on msn he will solve this. he is bb5 cs enginear
Old 03-05-2010, 03:39   #11 (permalink)
Member: 507832
Thanks Meter: 76
1 with mx key ripar sd
2 write pm 1,309
100% set ok
Old 05-01-2010, 12:21   #12 (permalink)
Member: 436305
Thanks Meter: 8
2 write pm 1,309
100% set ok
Your solution work if SECURITY_TEST failed!
We tallking about SL3 SIMLOCK_TEST failed!
The Following User Says Thank You to vipishe For This Useful Post:
Old 05-01-2010, 13:26   #13 (permalink)
MOURAD™'s Avatar
Member: 468587
Sonork: 100.1612429
Thanks Meter: 679
just return in WAIT MODE and wait..............
Old 05-01-2010, 14:58   #14 (permalink)
Member: 1237415
Thanks Meter: 26
Bro its' SL3 Phone...
Old 05-01-2010, 17:45   #15 (permalink)
Thanks Meter: 2,935
SIMLOCK_DATA corrupted! how to repair mobispot MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-18-2010 20:15
is possible repair simlock_Data corrupted !! ALFREBOX MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 03-10-2010 20:55
MX-KEY v3.3 revision 1.3 repairs SIMLOCK_DATA corrupted? angelcelu MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 01-29-2010 08:27
we are waiting Sl 3 SIMLOCK_DATA corrupted repair solution mohit_kripalu01 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 01-28-2010 14:42
how sloved SIMLOCK_DATA corrupted kakaomar MXKEY Nokia Flasher and Unlocker (by Alim Hape) 12 11-08-2009 14:59
Page generated in 0.53631 seconds with 8 queries
