03-19-2010, 15:59 | #1 (permalink) |
Freak Poster Join Date: May 2005 Age: 42
Member: 143499 Status: Offline Thanks Meter: 10 | How to repair watchdog timer on 6310i Then i put a sim card in and the phone turns off after 30seconds the imei when i type *#92702689# it was 35376900001209 mx-key read uem IMEI: 31376900001209 the next is that i see that the phone does not have a life timer???? log from scan: Phone Type: NPL-1 (Nokia 6310i) SW Version: V 7.00 04-11-04 NPL-1 (c) NMP. Imei plain: 31376900001209-8 Imei OTP: 31376900001209 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: C Language Pack: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Imei net: 31376900001209 Version: SIMLOCK server (c) NMP Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN what can i do?? |
03-19-2010, 16:29 | #5 (permalink) |
Member: 143499 Status: Offline Thanks Meter: 10 | Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.7920(18-03-2010), 1.0.0.12651(18-03-2010) ASIC ID: 0x1120 [UPP_8M ver: 2.0 or 2.1 or 2.2] SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 FlashID0: 0001 267E [AMD Am29N643,64 Mbits] page size: 64 K type: NOR area: 01000000-017FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78B8 Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164 Performing Flash Authentication ...OK UEM ID: 001BAC65:2984DA60 ASIC type: 2 UEM Imei: 31376900001209 Flash Imei: 31376900001209 MasterCode: 7613725273 RPL saved to "C:\mobileEx\3.3\data\backup\31376900001209_BACK.r pl" Phone Type: NPL-1 (Nokia 6310i) SW Version: V 7.00 04-11-04 NPL-1 (c) NMP. Imei plain: 31376900001209-8 Imei OTP: 31376900001209 Cellular System: GSM ASIC ID: 0x1120, type: 2 Ppm Id: C Language Pack: English,German,French,Italian,Dutch,Spanish,Turkis h,Portuguese Imei net: 31376900001209 Version: SIMLOCK server (c) NMP Provider: ALL Operator, Country: - Counter: 0/3, 0/10 br corvinu CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
11-09-2018, 00:48 | #7 (permalink) | |
No Life Poster Join Date: Nov 2004
Member: 92326 Status: Offline Thanks Meter: 205 | Quote:
How to repair watchdog problem with UB? | James_S | Universalbox | 7 | 11-17-2009 13:42 |
How to reset Life timer on v600 | reo | Motorola P2k | 1 | 06-16-2004 01:49 |
how to repair "Wrong Soft" on A35, v25 unlocked by Ziemens 1.22? | sat | x1x to x45/x50 | 4 | 12-15-2001 04:15 |
how to repair be4 auto on/off | acyl2000 | Alcatel & TCL Old Models | 0 | 06-04-2001 10:35 |
