03-25-2010, 16:44 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Pakistan Age: 45
Member: 383211 Status: Offline Thanks Meter: 131 | how repaire 1208 imei ?????? with mxkey Phone Type: RH-105 SW Version: V 5.80 14-11-08 RH-105 (c) NMP Imei plain: ??????????????-? Product Code: 0550577 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. TimeStamp: 2008-11-21T10:07:24Z SW Version: 5.80 Variant Version: 001 ProductProfile: RH105_0550577_5.80_001.spr Simlock: 0550577_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000010002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN |
The Following User Says Thank You to pakmobiles For This Useful Post: |
03-25-2010, 17:14 | #4 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | ok i find it.whene u login the simply click on Manual.whene i reqeust manualy.the follwing message come and not any responce from server.plz guide me setup by setup if u can Connecting to server ...OK, Login ... Hello C0803F38, you have 2010 credits left. Connecting to server ...OK, Login ... Last edited by pakmobiles; 03-25-2010 at 17:21. |
03-26-2010, 05:54 | #6 (permalink) |
Member: 383211 Status: Offline Thanks Meter: 131 | i try to use after login in online logger.but result is no thing.but in logger dst4 0 and dct4+ 0 and dct4imei + product code is 50.any thing wrong woth my credits Phone Type: RH-105 SW Version: V 5.80 14-11-08 RH-105 (c) NMP Imei plain: ??????????????-? Product Code: 0550577 Cellular System: GSM ASIC ID: 0x2292, type: 11 Ppm Id: IA Language Pack: - not available. TimeStamp: 2008-11-21T10:07:24Z SW Version: 5.80 Variant Version: 001 ProductProfile: RH105_0550577_5.80_001.spr Simlock: 0550577_SimLockDataVerifier_vDCT4.sim Imei plain is invalid !!! Imei net: 00000000000000 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 0000000000000000 PROFILE_BITS: 0000000000010000 SIMLOCK_DATA corrupted! ASIC ID: 0x2292 [UPPCosto ver: 1.3] SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 FlashID0: 00EC 2268 [Samsung K8S3215ETE,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF FlashID1: 0000 0001 [unused/removed] ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514 Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0 Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168 Performing Flash Authentication ...OK UEM ID: 0048F309A3BDA66 ASIC type: 11 UEM Imei: 35809301548251 Connecting to server ...OK, Login ... |
succesful repaire 7210s contactservice with mxkey | pakmobiles | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 03-29-2010 09:45 |
Help me !!! How to change dct4 imei with mxkey | MTB_NK | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 03-29-2010 09:00 |
how to skip sx4 with mxkey | Uwo_jj | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 02-08-2010 20:00 |
Put in this thread all successfull story of Dct4 Imei???? with Mxkey | mobilecitycbk | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 1 | 06-17-2009 21:28 |
how repair L7 imei with smartmoto2.16??? | guo_xiaoguang | Smart-Clip | 5 | 12-06-2007 18:11 |
