Old 10-21-2009, 21:01   #1 (permalink)
Member: 52763
Thanks Meter: 35
how to repaire n96 Contact Service
Phone Type: RM-247 (Nokia N96-1)
SW Version: V ICPR72_08w41.2 25-11-08 RM-247 (c) Nokia
Imei plain: 35486302427238-0
Product Code: 0543722
Language Pack:
- not available.
This phone have PM308 protected, SD security in not restorable.
- Avoid manual erase to this phone !
SIMLOCK seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST failed!
Imei: 354863024272380
Version: SIMLOCK SERVER
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 10-21-2009, 21:16   #2 (permalink)
Member: 1060683
Sonork: 100.1593478
Thanks Meter: 203
U can't conect pmm auth Server write pm file
Old 10-21-2009, 23:41   #3 (permalink)
ptt
ptt's Avatar
Member: 348680
Thanks Meter: 1,273
@ djamel852
for " SECURITY_TEST failed! " you need to write PM file with fields 1 & 309, using SX4 Auth
you can download an edited PM file from http://www.ptt.4mg.com/Gsmforum/
and if MX-Key SX4 server offline, you can use JAU SX4 ( Free server, for more info search in Nokia section )
Old 10-22-2009, 09:02   #4 (permalink)
Member: 52763
Thanks Meter: 35
Originally Posted by ptt View Post
@ djamel852
failed to write
Scanning local SX4 Card ...
No SX4 Card found.
Authenticating using security server ...
Connecting to server[nkrpl.biz] ...MXKEY-SX4 ver 2.5(ID), hello 86.60.36.75
SUPERDONGLE auth succeeded!
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (98 bytes)
Warning: failed to write 1 - 18 (98 bytes)
Warning: failed to write 1 - 20 (98 bytes)
Warning: failed to write 1 - 22 (16 bytes)
Warning: failed to write 1 - 23 (4 bytes)
Warning: failed to write 1 - 24 (84 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 26 (110 bytes)
Warning: failed to write 1 - 28 (98 bytes)
Warning: failed to write 1 - 29 (10 bytes)
Warning: failed to write 1 - 31 (98 bytes)
Warning: failed to write 1 - 33 (36 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Warning: failed to write 1 - 35 (16 bytes)
Warning: failed to write 1 - 37 (4 bytes)
Warning: failed to write 1 - 39 (36 bytes)
Warning: failed to write 1 - 44 (182 bytes)
Warning: failed to write 1 - 45 (182 bytes)
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Completed in 0.906 s
Old 10-22-2009, 09:18   #5 (permalink)
shaazad's Avatar
Member: 1146078
Thanks Meter: 96
write pm 308 with sx4 server and unlock it agian
How to repair 5130 contact service with fps-10 with sx4 smartcard...! swechacnu Nokia Base Band 5 ( BB-5 ) 11 12-28-2012 20:26
how to repair 2700c Contact Service andre128 Nokia Digital Core Technology 4 ( DCT-4 ) 1 10-07-2009 04:35
How to repair 6300 contact service with ub???? svchost Universalbox 9 05-15-2009 22:09
Page generated in 0.20577 seconds with 9 queries
