03-06-2012, 17:37 | #1 (permalink) |
Freak Poster Join Date: May 2010
Member: 1307292 Status: Offline Thanks Meter: 10 | How to Reset User Code Nokia 2710c and Nokia x2-01 Rm-709 (ANSWERED) i flashed it with usb.still not able reset the user code i cant read the code and after flashing when it ***** in normal mode . it stop on password i can't get f bus cable in the market,and also i cant find the pin out for it in forum is there any solution for it ??? |
03-07-2012, 09:01 | #6 (permalink) | |
Member: 1307292 Status: Offline Thanks Meter: 10 | Quote:
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C080C739 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00001E01 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: nmwcdnsuc, ver: 7.1.32.72 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: rm709__08.70.mcusw [BB5,XSR 1.6] size: 26.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000E284966F8EC64AD7154B9587BBEA4D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741004100473_CE RT.rpl). CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6F [] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 7.610 s Processing PPM file: rm709__08.70.ppm_h2 [BB5,XSR 1.6] size: 5.15 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.360 s Processing CNT file: rm709__08.70.image_h2_059J2H3 [BB5,XSR 1.6] size: 24.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Converting UCP blocks to 128 K. Error converting UCP! Task failed at (08000009)!!! Last RX buffer: 80 10 6F 00 | |
03-07-2012, 09:56 | #8 (permalink) |
Member: 1307292 Status: Offline Thanks Meter: 10 | flash logs after ticking force 128k nokia 2710c MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C080C739 Using device: USB ROM and HTI, FW ver: 00.50, SN: 00001E01 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012) Processing MCU file: 7F2F099D_rm586__09.67.mcusw [BB5,XSR 1.6] size: 24.65 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM213x1 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 3304428509427AB492B83DBDB7BFCFDB31654904 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35829403310687_CE RT.rpl). CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 31.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-01FFFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 84CDC75F [RAP Certificate 195 v.1] sent CMT UPDAPP block sent CMT MCUSW block sent CMT GENIO_INIT block sent Programming completed in 6.750 s Processing PPM file: 99B255CA_rm586__09.67.ppm_mec [BB5,XSR 1.6] size: 4.50 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 6.50 MB CMT FLASH,MuxOneNAND area [02000000-0267FFFF] Flash programming ... Programming completed in 1.188 s Processing CNT file: 3E8EAA53_rm586__09.67.image_mec_black [BB5,XSR 1.6] size: 11.16 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB CMT FLASH,MuxOneNAND area [02800000-0753FFFF] Formating partition ... Converting UCP blocks to 128 K. Error converting UCP! Task failed at (08000009)!!! Last RX buffer: 80 10 6F 00 |
03-07-2012, 10:31 | #9 (permalink) |
Member: 1307292 Status: Offline Thanks Meter: 10 | i managed flashing and reseting with version 3.5 rev 1.5 here is logs for x2-01 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C080C739 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm709__08.70.mcusw [BB5,XSR 1.6] size: 26.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000E284966F8EC64AD7154B9587BBEA4D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741004100473_CE RT.rpl). CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6F [] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 7.734 s Processing PPM file: rm709__08.70.ppm_h2 [BB5,XSR 1.6] size: 5.15 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.453 s Processing CNT file: rm709__08.70.image_h2_059J2H3 [BB5,XSR 1.6] size: 24.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 6.578 s Total time for flashing process(boot+erase+write) was 30.234 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdc\X2-01 USB Phonet, PORT_ID: 352E42F5 Verifying communication to device OK. Phone type: RM-709 (X2-01) SW version: V 08.70 29-07-11 RM-709 (c) Nokia Imei plain: 35741004100473-0 Product code: 059G230 Battery voltage: 3794 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC00000401022C00, ver: 003.006 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357410041004730 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.109 s |
03-07-2012, 10:33 | #10 (permalink) |
Member: 1307292 Status: Offline Thanks Meter: 10 | i managed flashing and reseting with version 3.5 rev 1.5 b4 i was using rev 1.7 here is logs for x2-01 MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C080C739 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm709__08.70.mcusw [BB5,XSR 1.6] size: 26.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 0000000000E284966F8EC64AD7154B9587BBEA4D CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,NOR, asic:CMT Storage3: 0010 0011 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 0020 0030 - 0000 0131 [ST NAND-1G] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35741004100473_CE RT.rpl). CMT PAPUBKEYS HASH: 37955B6FC432998EF0DB240E332228384D19ED09 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 33.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-012FFFFF] CMT FLASH,MuxOneNAND area [01300000-01DFFFFF] CMT FLASH,MuxOneNAND area [02600000-029FFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 37955B6F [] sent CMT UPDAPP block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 7.734 s Processing PPM file: rm709__08.70.ppm_h2 [BB5,XSR 1.6] size: 5.15 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 8 MB CMT FLASH,MuxOneNAND area [01E00000-025FFFFF] Flash programming ... Programming completed in 1.453 s Processing CNT file: rm709__08.70.image_h2_059J2H3 [BB5,XSR 1.6] size: 24.61 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 75.31 MB CMT FLASH,MuxOneNAND area [02A00000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 6.578 s Total time for flashing process(boot+erase+write) was 30.234 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdc\X2-01 USB Phonet, PORT_ID: 352E42F5 Verifying communication to device OK. Phone type: RM-709 (X2-01) SW version: V 08.70 29-07-11 RM-709 (c) Nokia Imei plain: 35741004100473-0 Product code: 059G230 Battery voltage: 3794 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC00000401022C00, ver: 003.006 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357410041004730 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 1.109 s |
03-07-2012, 10:44 | #11 (permalink) |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | rev 1.7 n rev 1.8 needs to press ok after usb flashing, if it cant go to local mode, no hope to unlock user code. rev 1.5 n rev 1.6 no need to press anything, just wait til it done n go to local mode itself. im still wondering what is the use of press ok after usb flashing in rev 1.7 n rev 1.8. br |
03-07-2012, 10:49 | #12 (permalink) |
Member: 1307292 Status: Offline Thanks Meter: 10 | i managed flashing and reseting with version 3.5 rev 1.5 b4 i was using rev 1.7 here is logs for 2710c MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C080C739 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: 7F2F099D_rm586__09.67.mcusw [BB5,XSR 1.6] size: 24.65 MB Supported Ids: 2200050920030000, 22000509200C0000 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B CMT SYSTEM ASIC ID: 000000000000000022000509200C0000 [BCM21351 ver: 1.0] CMT EM0 ID: 00005361 CMT PUBLIC ID: 3304428509427AB492B83DBDB7BFCFDB31654904 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E CMT ROM ID: DE56D582BDDE7A3A Loading CMT secondary boot code SecondaryBoot: BCM21351_usb2nd.fg [BB5] version: 11.14.0 revision: 2.1 size: 0x3940 Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0321 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). Rpl(Certificate) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35829403310687_CE RT.rpl). CMT PAPUBKEYS HASH: 84CDC75F79F52BBAE46EA3A70C9240861412C480 Storing certificate [NPC, CCC, HWC, RND, R&D] ...OK Partitioning.... Partitioning complete Erase size: 31.88 MB CMT FLASH,MuxOneNAND area [00000000-0001FFFF] CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-01FFFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT ADA block sent CMT PRIMAPP block sent CMT RAP3NAND block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 84CDC75F [RAP Certificate 195 v.1] sent CMT UPDAPP block sent CMT MCUSW block sent CMT GENIO_INIT block sent Programming completed in 6.937 s Processing PPM file: 99B255CA_rm586__09.67.ppm_mec [BB5,XSR 1.6] size: 4.50 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 6.50 MB CMT FLASH,MuxOneNAND area [02000000-0267FFFF] Flash programming ... Programming completed in 1.281 s Processing CNT file: 3E8EAA53_rm586__09.67.image_mec_black [BB5,XSR 1.6] size: 11.16 MB Supported Ids: 2200050920030000, 22000509200C0000 Erase size: 77.31 MB CMT FLASH,MuxOneNAND area [02800000-0753FFFF] Formating partition ... Flash programming ... Programming completed in 3.172 s Total time for flashing process(boot+erase+write) was 21.391 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 204AC93B Waiting for USB device removal ...OK Waiting for USB device arrival ... Device connected: nmwcdc\Nokia 2710 Navigation Edition USB Phonet, PORT_ID: 7A761BF Verifying communication to device OK. Phone type: RM-586 (Nokia 2710c-2) SW version: V 09.67 09-08-10 RM-586 (c) Nokia Imei plain: 35829403310687-0 Product code: 059B3L1 Battery voltage: 3815 mV, current: 1 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00BC0000030102F201, ver: 006.014 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 358294033106870 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 8000000000000002 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 6.843 s |
03-07-2012, 10:58 | #14 (permalink) | |
after flashing it was asking for password.when i try to reset all it was giving an error. any way the problem is solved.... | |
03-07-2012, 11:02 | #15 (permalink) | |
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
good for u bro and yes, some phones wont go to local mode after flashing in rev 1.7/1.8. it happened to me too sometimes. if u can go to local mode by clicking buscheck, no need to flash at all bro. br | |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
