11-28-2011, 11:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2008 Location: Faisalabad pakistan
Member: 900083 Status: Offline Thanks Meter: 601 | c2-01 restart problem need help MXKEY [FT SCR2000 0], SN: C085F4F3 Connection status: UHCI:HUB::USB 2.00 (Full-speed) Driver: NMWCD, ver: 7.1.32.72 Module ver: 1.0.0.19228(10-11-2011), Library ver: 1.0.0.13150(10-11-2011) Processing MCU file: rm721__11.10.mcusw [BB5,XSR 1.6] size: 28.57 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB device ... Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3367B01F CMT SYSTEM ASIC ID: 000000010000022600000001020C192102044100 [RAPS2 ver: PA 4.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: 1A100115A1F85840C7C38D7950B9907F1BDDF30F CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 7B045400E1752022F9EB80B0DEA9C65D CMT ROM ID: 67E82268F29CEA60 Loading CMT secondary boot code SecondaryBoot: RAP3Gv40_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3AC0 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAP3Gv40_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0x91BD2 Supported Ids: 0203192102004000, 020C192102004000, 0203192102024000, 020C192102024000, 020C192102004100, 0203192102004100, 020C192102014100, 0203192102014100, 020C192102014000, 0203192102014000, 020C192102034000, 0203192102034000, 0203192102024100, 020C192102024100, 0203192102034100, 020C192102034100, 0203192102054100, 020C192102054100, 0203192102044100, 020C192102044100 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 3367B01F FUR: Adding Asic CMT as client OK. Reading CMT NPC (0x168 bytes). Reading CMT VARIANT (0x0 bytes). Reading CMT CCC (0x160 bytes). Reading CMT HWC (0xD4 bytes). Reading CMT R&D (0x0 bytes). Reading CMT PARTNERC (0x0 bytes). NPC_DATA saved OK CCC_DATA saved OK HWC_DATA saved OK RPL saved to "C:\mobileEx\3.5\data\backup\BB5_35737604165655_CE RT.rpl" CMT PAPUBKEYS HASH: 8443ECD57D2EDADDAADBAD248F1B3B559E14D184 Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 37.69 MB CMT FLASH,MuxOneNAND area [00020000-000203FF] CMT FLASH,MuxOneNAND area [00060000-0009FFFF] CMT FLASH,MuxOneNAND area [000A0000-0025FFFF] CMT FLASH,MuxOneNAND area [003E0000-005DFFFF] CMT FLASH,MuxOneNAND area [005E0000-010DFFFF] CMT FLASH,MuxOneNAND area [01EC0000-01EDFFFF] CMT FLASH,MuxOneNAND area [027C0000-02CBFFFF] CMT FLASH,MuxOneNAND area [077C0000-07B3FFFF] CMT FLASH,MuxOneNAND area [010E0000-01EBFFFF] Formating partition ... Flash programming ... CMT ADA block sent CMT KEYS block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT PAPUBKEYS: 8443ECD5 [] sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent Programming completed in 37.719 s Processing PPM file: rm721__11.10.ppm_meac [BB5,XSR 1.6] size: 5.80 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 8.87 MB CMT FLASH,MuxOneNAND area [01EE0000-027BFFFF] Flash programming ... Programming completed in 7.344 s Processing CNT file: rm721__11.10.image_meac_059D5M7_006 [BB5,XSR 1.6] size: 16.33 MB Supported Ids: 0203192102004100, 020C192102004100, 0203192102024100, 020C192102024100, 0203192102044100, 020C192102044100 Erase size: 75.06 MB CMT FLASH,MuxOneNAND area [02CC0000-077BFFFF] Formating partition ... Flash programming ... Programming completed in 20.875 s Total time for flashing process(boot+erase+write) was 1 min 24.656 s Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Waiting for device boot up ... Device connected: nmwcdc\Nokia C2-01 USB Phonet, PORT_ID: 19BE53B3 Verifying communication to device OK. Phone type: RM-721 (Nokia C2-01) SW version: V 11.10 13-05-11 RM-721 (c) Nokia Imei plain: 35737604165655-7 Product code: 059D5M7 Battery voltage: 4004 mV, current: 102 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: NI00IIIIRR0301035602, ver: 001.002 SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid CMLA_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 357376041656557 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN Nokia USB ROM disconnected. |
03-04-2014, 17:02 | #5 (permalink) |
Insane Poster Join Date: Jan 2011 Location: nalgonda
Member: 1496996 Status: Offline Sonork: vemulanetaji Thanks Meter: 8 | i have one c2-01 restrat after some time some time 3 or 4 sec later or some time afte i have one c2-01 restrat after some time some time 3 or 4 sec later or some time after 1 or 2 minuts i flashed with this file but problem is still same anyone help me about this problem |
03-07-2014, 09:52 | #6 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: MXBOX THUNDER Helpdesk Age: 50
Member: 262425 Status: Offline Sonork: 100.1617691 Thanks Meter: 1,264 | Quote:
Follow Mxkey Rules for posting & Post Logs, Now post Buscheck Logs, Do Selftest & Post it's Logs for assistance. BR, ZUBER | |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
