03-26-2010, 09:54 | #12 (permalink) |
No Life Poster Join Date: Jun 2006 Location: king solomons temple
Member: 301387 Status: Offline Thanks Meter: 51 | @hasnain BootLoader not responding, mostly RAM problem ! how solved this error just griped the cable hard and press bus check and all ok after that i already broke the cable after griped the cable hard..... he he he by just following your advice..... |
03-26-2010, 10:40 | #13 (permalink) |
Member: 301387 Status: Offline Thanks Meter: 51 | i have 3pc and this partiular version 1.7 does not work in these PCs.... i got back to 1.6 its working fine... no problema.... what can you comment... and one thing more most bb5 gets dead ater flashing... this is really bugs in 1.7 and has to be corrected... and not mere cable problem or as u stated 1. not good connectivity of cable pins with mobile 2. ur using built in usb ( due to low power got this error ).... 3PCs workin good in 1.6.... |
BootLoader not responding, mostly RAM problem Solved 1000% | tanveeranjum | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 28 | 06-05-2010 06:56 |
BootLoader not responding, mostly RAM problem | sandhu36 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 04-15-2010 15:26 |
BootLoader not responding, mostly RAM problem ! | rana_jee | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 6 | 02-04-2010 16:31 |
