04-03-2011, 10:40 | #1 (permalink) |
Freak Poster Join Date: Apr 2010
Member: 1275426 Status: Offline Thanks Meter: 9 | How to solve 'contact service' 3110, mxkey team pls (ANSWERED) 1st im make full backup 2nd, im make npc backup 3rd, im erase full flash 4th, im flash new ver. 5th, im restore full rpl backup & npc backup 6th, im repair sd 7th, im pm auth. & write good pm 8th, im recover cert. but not solve, help me mxkey team pls, Thx Phone Type: RM-237 (Nokia 3110c) SW Version: V 07.30 07-05-09 RM-237 (c) Nokia. Imei plain: 35606103507136-6 Product Code: 0550691 Language Pack: - not available. SIMLOCK seems to be valid SUPERDONGLE_KEY[MX] seems to be valid CMLA_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356061035071366 Version: SIMLOCK SERVER VERSION 63 Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
04-03-2011, 11:36 | #6 (permalink) | |
No Life Poster Join Date: Mar 2005 Location: tuttotelefonia
Member: 125945 Status: Offline Thanks Meter: 495 | Quote:
the procedure that you have DONE, is for repair Sim Lock, for Repair Security Area, which i see in this moment from your Log, is THIS: We solved some bugs on server side at first SX4 Auth when phones had bad PM uploaded (e.g. PM308 from another phone, empty PM308, ...) Now all SD repair should work well. Here is general repair procedure. It will repair any phone (SL1, SL2) with any kind of damaged PM, except phones with RPL NPC damaged (IMEI 123456....). It will repair ONLY SD (not Simlock) for supported hashes "pure SL3" based phones. 1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309) 2. make Simlock RPL repair 3. make SD RPL repair 4. make SUPER SX4 Auth then write PM1 and PM309 from SAME phone model 5. eventualy (if phone had bad RPL written by other people) write RPL CCC, HWC, VARIANT from SAME phone model, Try and post resultated, BR Max P.d. your procedure Done, was for repair Sim Lock from Error 0X1.....!!!! | |
The Following User Says Thank You to .:Ripgsm:. For This Useful Post: |
04-03-2011, 11:55 | #7 (permalink) | |
No Life Poster Join Date: Oct 2009
Member: 1149800 Status: Offline Thanks Meter: 211 | Quote:
hellooooooooooooooooo bro! use search button, this case has been discussed thousand times in thousand threads... one of these threads: http://forum.gsmhosting.com/vbb/f550...ailed-1214364/ good luck bro br | |
04-03-2011, 15:55 | #10 (permalink) |
No Life Poster Join Date: May 2006 Location: Pakistan
Member: 277937 Status: Offline Thanks Meter: 48 | guys some time the set got hardwear problem in this case some time always seemed error security test fail so check hardwear \ some time seccurity test passes but still contact server check v bat, bsi ways....... |
04-04-2011, 05:05 | #11 (permalink) | |
No Life Poster Join Date: Jul 2004
Member: 73565 Status: Offline Thanks Meter: 5,062 | Quote:
all good suggestions are said by other member. i don't have anymore to say. beside, this kind of case is discussed many times. BR | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
