01-04-2010, 11:37 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Location: RO Age: 47
Member: 104946 Status: Offline Thanks Meter: 33 | How to unlock 5800 V 11.0.009 with mx-key? Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23433F, DATA=23433F BLOCK 2: 1=LOCKED (MCC+MNC): 23486F, DATA=23486F Backup already exist. Using device: UFS_USB V2.8 (c) SarasSoft 2007. Library version: 1.0.0.11446, Date: 25-11-2009 ROOT KEY HASH: CAEEBB65D3C48E6DC73B49DC5063A2EE ROM ID: 4B9B75103E691FF8 Sending SecondaryBoot(0x3AC0 bytes) ...OK Sending PreLoader(0x2E4 bytes) ...OK Sending ROM(0x190C bytes) ...OK Sending SecurityBlock(0x2000 bytes) ...OK Sending SimlockBinary(0x190 bytes) ...OK Sending Certificate(0x1A20 bytes) ...OK Calculating NCK using security server ... Connecting to server[main.mxkey.biz] ...OK, Login ... failed to get key! Reading Simlock info ... Imei net: 354183026371068 Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=LOCKED (MCC+MNC): 23433F, DATA=23433F BLOCK 2: 1=LOCKED (MCC+MNC): 23486F, DATA=23486F http://forum.gsmhosting.com/vbb/showthread.php?t=835796 You need a full PM back-up and an RPL from the phone. Downgrade it to V21.0.25 product code 0573738 use the function rebuild simlock from PM and select the PM back-up unlock the phone (save the unlocking code calculated) flash with erase file 5800_Erase_256MB_kashi4gul with skip ape enabled Flash with firmware E71 v300 product code 0559569 with "skip APE" enabled only COR and PPM Write back the PM 308 and 120 back-up Full flash again the mobile with the original firmware APE included Write back the RPL sx4 auth write back FULL PM no 308 no 120 start the phone Input the unlocking code via keyboard or via fbus. My phone have version Product Code: 0576921 ApeCoreSw: V 11.0.009 .I must upgrade it to V21.0.25 product code 0573738 with tick downgrade ? |
01-04-2010, 11:41 | #2 (permalink) |
Freak Poster Join Date: Sep 2008 Location: Valencia, Spain
Member: 867007 Status: Offline Thanks Meter: 42 | no man dosen't work with mxkey if you are using J.A.F as interface, and about downgrade it is for the versions higher then 21.0.25 like 30.xx.xx. and as i know mobileex 3.3 rev.1 has a bug in unlocking this models you need to use 3.2 rev. 5.4, but you can't because version has expired on 25 dec. |
01-04-2010, 11:56 | #5 (permalink) | |
Member: 867007 Status: Offline Thanks Meter: 42 | Quote:
no you don't need to do this, if you upgrade to v.30 you may not have a chance to unlock. you must download mobileex 3.2 rev5.4 and try, with ufs as interface and you need to change computer's date before 25 dec 2009. | |
The Following User Says Thank You to cooldjmc For This Useful Post: |
01-04-2010, 12:00 | #6 (permalink) |
Member: 104946 Status: Offline Thanks Meter: 33 | It"s workingggggggggggggg! I just used old version of mx-key 3.2 5.4 installed in same folder C:\mobileEx\3.2,from first try! Phone Type: RM-356 (Nokia 5800 XpressMusic) SW Version: V ICPR72_08w47.1 23-01-09 RM-356 (c) Nokia Imei plain: 35418302637106-8 Product Code: 0576921 ApeCoreSw: V 11.0.009 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 354183026371068 Version: SIMLOCK SERVER Provider: Orange, Country: United Kingdom Counter: 0/3, 0/10 CONFIG_DATA: 2343300000000000 PROFILE_BITS: 8000000000000000 BLOCK 1: 1=OPEN, DATA=23433F BLOCK 2: 1=OPEN, DATA=23486F |
how to unlock 5800 ver21.0.25 | klmamn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 24 | 06-12-2011 09:24 |
how to unlock 5800 with mx-key | himanshu taldar | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 21 | 07-30-2010 12:31 |
HOW to unlock iphone 3g v3.0 modem software 5.11.07 | VODAFONES | iPhone 2 / iPhone 3G / iPhone 3GS | 10 | 11-01-2009 17:34 |
how to unlock 5800/N96 with Mx key? is it possible or not? | malikzahidawan | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 3 | 08-08-2009 21:12 |
how to unlock n95 RM159 v21.0.0016 with bb5box | Haouas | Nokia Base Band 5 ( BB-5 ) | 0 | 07-21-2008 23:02 |
