02-18-2010, 09:15 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: georgia tbilisi
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | how to write rpl on dct4? i have 8800 titan with changed uem and want to write rpl and imei but cant find turtorial or any fag for this can you help me? |
02-18-2010, 09:27 | #3 (permalink) |
Banned Join Date: Mar 2006
Member: 239004 Status: Offline Sonork: 100.1589817 Thanks Meter: 388 | Run Nokia Tool, Select Generation [ DCT4 ] Select [ Service ] Select Online Logger,Check Use Dongle ID, Insert User & Pass,And Login, Then Select Dct4 , and connect cable then Press [ Do Selected Job ] |
02-18-2010, 10:30 | #4 (permalink) |
Member: 194939 Status: Offline Sonork: 100.168.25.6 Thanks Meter: 623 | accses violation at adress 02ce129b. read of adress 0000000 ASIC ID: 0x1052 [TikuEdge ver: 1.1] SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398 Supported Ids: 1051, 1052, 2051 FlashID0: 00EC 22F8 [Samsung K8S2815ETA,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF FlashID1: 00EC 0020 [Samsung KFM1216Q2M,512 Mbits] type: NAND hw: EIJA(E) FlashID2: 0000 0001 [unused/removed] FlashID3: 0000 0001 [unused/removed] ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5 Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8 Supported Ids: 1051, 1052, 2051 Performing Flash Authentication ...OK UEM ID: 0041AE9F:3B8ADA60 ASIC type: 6 UEM Imei: Empty Connecting to server ...OK, Login ... Hello xxxxxxxxxxx, you have 1000 credits left. |
how to write rpl dct4 | jodevas | Universalbox | 4 | 07-01-2009 08:27 |
how to write rpl wd2 dct4 | arushar1 | Universalbox | 2 | 09-03-2008 10:36 |
How to Write RPL on BB5 | asadnow2k | Universalbox | 2 | 08-29-2008 18:08 |
