Old 12-19-2011, 02:07   #31 (permalink)
lam_spiderman's Avatar
Member: 1129593
Thanks Meter: 55
Originally Posted by MANOLE View Post
I made it sticky, finally something useful comes from Philippines
BR,
Manole
it ís very good
The Following User Says Thank You to lam_spiderman For This Useful Post:
Old 12-19-2011, 03:04   #32 (permalink)
KingOfGsm's Avatar
Member: 85019
Sonork: 100.1603419
Thanks Meter: 37
yes sure good news more will come for sure
The Following User Says Thank You to KingOfGsm For This Useful Post:
Old 12-19-2011, 07:09   #33 (permalink)
Member: 430612
Thanks Meter: 301
[QUOTE=analot;7979914]After I install the latest version of mobileex_setup_v3.5_rev1.620111213_0
I encountered this problem:
This procedure help me out with that problem:
After that, just Run mobileEx 3.5 (rev1.6) or Restart App:
when i open device manager i dont find hti smartcard reader (winusb) instead i only find smart card readers and below it show usb token holders only.plz what could be my problem with this
box? flash light stay flicking plz guy i need help
Old 12-19-2011, 07:12   #34 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
nice clue , that's 100000% right clue
Regard,
The Following User Says Thank You to .::ARD::. For This Useful Post:
Old 12-19-2011, 08:59   #35 (permalink)
Member: 918154
Sonork: As Long As I Can
Thanks Meter: 22
[QUOTE=luyanda;7996604]
try this bro....
first uninstall all..software n driver...then delete MobileEx folder in C://
then...install the software..(Don't changes anything just next n next...till installation completed)
then
1.run MobileEx with mxkey dongle plugged..if u have...if detected then/or..
2.run MobileEx (without Dongle or HTI Plugged) then no security dongle appears...
3. Push HTI Update...then plug HTI when ask..wait..till finish n successful but don't restart the software till all driver installation completed...if all HTI n Smart Card Reader driver installation done then restart the software...(push yes to restart the sofware)
4.Synchronize..Done
Work For me...hope useful for other....
The Following 2 Users Say Thank You to ichanx For This Useful Post:
Old 12-20-2011, 12:37   #36 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 180
not worked window sp 3
Old 12-20-2011, 16:49   #37 (permalink)
Member: 1706888
Sonork: 100.1624068
Thanks Meter: 16
try this way
Rockey for earlier versions of this driver click yes if in fact happened ...... No Security Dongle Detected
And for this new version if there rockey2000 must install a command on click yes .... weakness .... was here yesterday and there was no sempet click No Security Dongle Detected
Finally, reinstall mobileex_setup_v3.5_rev1.6 and solved step by step ......!!!
Essentially if there is a command rockey2000 install drivers just click yes and wait for it to finish up next> and next > ..........
sp3 tested by my broo..........
The Following User Says Thank You to dj_fenola For This Useful Post:
Old 12-20-2011, 19:29   #38 (permalink)
Member: 1005947
Thanks Meter: 6
hi, i have problem installing th HTI FLASHER, any solution?? i install the driver but not works!
Old 12-21-2011, 03:51   #39 (permalink)
Member: 1158416
Thanks Meter: 182
i also encounter that before. i only download latest version and install, if you ask to install this driver or overwrite just click Yes. after installing all necessary files and you have encounter No Security Dongle Detected, just follow above procedure
Old 12-21-2011, 05:58   #40 (permalink)
.::ARD::.'s Avatar
Member: 1705891
Sonork: 100.1604564
Thanks Meter: 8,139
yes that right
it was trick at 05-04-2011, 06:29 PM
check out this clue too
Regard,
Old 12-22-2011, 13:32   #41 (permalink)
Member: 1706159
Thanks Meter: 2
hti box no dead contact me 100000000000000% ok mx box no dead contact me [email protected]
+8801712030683
Old 12-23-2011, 16:04   #42 (permalink)
memobiles's Avatar
Member: 596071
Thanks Meter: 160
Originally Posted by SCPGSM8 View Post
yes that right
Regard,
after this solution when i install hti card reader window xp crash and blue screen driver error and after restart again old samrt card driver with yellow error but hti flasher update successfully and dect i cant understand where problem because when update complet hti box again same hti flasher drver 10 error please give me solution i install fresh xp sp2
please give working hti card reader driver which not creat blue screen hardware error and xp crashing
The Following 2 Users Say Thank You to memobiles For This Useful Post:
Old 12-23-2011, 17:39   #43 (permalink)
Member: 1158416
Thanks Meter: 182
Just Download the latest version 3.5 rev 1.6 and reinstall all, overwrite all drivers.
Old 01-09-2012, 12:24   #44 (permalink)
Crazy Poster
Member: 316534
Thanks Meter: 5
thanks sir working solution very very thanks
The Following User Says Thank You to rathod For This Useful Post:
Old 01-09-2012, 13:27   #45 (permalink)
fatafi's Avatar
Member: 1669858
Sonork: 100.1609806
Thanks Meter: 27
thank's friend
I fix this problem
thank's for thread
The Following User Says Thank You to fatafi For This Useful Post:
Anybody know solution Robi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 12-10-2014 12:35
Solution for GSM phones!?!?!?!? todosije Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-16-2010 05:52
5110 Security Code Help! cahrisma Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 07-05-2010 09:04
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
!!!!!!TO ALL NOKIA 51XX/61XX SP LOCKS 1,2,3,4 SOLUTION latest news!!!!! spterminator Main Sales Section 2 08-13-1999 05:55
Page generated in 0.26579 seconds with 10 queries
