Old 02-02-2012, 11:59   #1 (permalink)
snipper_gsm's Avatar
Member: 601176
Thanks Meter: 160
HTI box orange error in xp3 fixed this
HTI box orange error in xp3 fixed this problem HTI TEAM...
operating system pirated,,, or Windows Xp 3
HTI not install.... missing driver....
finish install here run this message....
Uninstall and then reinstall your device.
To resolve the problem that is causing Device Manager to show an error code for your device, try uninstalling and then reinstalling the device.
To uninstall your device
Open Device Manager.
If the category for your device is not expanded, double-click the category.
Under the category for your device, right-click the device that you want to uninstall, and then click Uninstall.
In the Confirm Device Removal dialog box, click OK.
Note
To open Device Manager, click Start, click Control Panel, click Performance and Maintenance, and then click System. In the System Properties dialog box, click the Hardware tab, and then click Device Manager.
Once you have removed your device, use the Add Hardware Wizard to reinstall it.
To reinstall your device
Close any open programs.
Start the Add Hardware Wizard.
Click Next, and wait for Windows to search for Plug and Play devices. Most new devices are Plug and Play, so you rarely need to go beyond this step.
If no Plug and Play devices are found, a list of devices appears. Click Add a new hardware device, and then click Next.
Click Install the hardware that I manually select from a list, and then click Next.
In the Common hardware types list, click the appropriate device category, and then click Next.
In the Manufacturers list, click the manufacturer of your device; in the Models list, click the model name.
Or, click Have Disk if you have an updated or manufacturer-supplied driver to install for your device.
Click Next, and then follow the wizard's instructions to complete the installation.
Note
To open the Add Hardware Wizard, click Start, click Control Panel, and then click Printers and Other Hardware. Under See Also, click Add Hardware.
Does uninstalling and reinstalling your device solve the problem?
No, I still have a problem with my device.
Yes, this solves the problem.
I want to skip this step and try something else.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
Page generated in 0.15850 seconds with 9 queries
