04-17-2013, 10:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2011
Member: 1522958 Status: Offline Thanks Meter: 24 | HTI Error 10 Perfect Solution So if you have this error (device cannot be started error 10) this solution is for you: 1.Unplug HTI box 2.Delete following files manually C:\\WINDOWS\system32\DRIVERS\WinUSB.sys C:\\WINDOWS\system32\WdfInstaller01009.dll C:\\WINDOWS\system32\WinUSBCoInstaller2.dll C:\\WINDOWS\system32\WUDFUpdate_01009.dll 3.Plug in HTI box 4.Press Start>Run>type devmgmt.msc and press ok 5.There's should be 2 drivers with Exclamation mark 5.1 One of them in Smart Card Readers 5.2 Another in Universal Serial Bus Controllers 6. IMPORTANT! First you need to update smart card drivers Double click on it, go to driver tab>update driver>select install from a list or specific location>next select don't search select manually and select HTI Plus Smart card Reader (WUDF). If drivers are not listed select them manually from mxkey software folder. 7. When smartcard drivers are installed do the same thing for HTI flasher interface 8. Thats it your problem will be solved 100% Thanks for reading and good luck |
The Following 2 Users Say Thank You to kamertonas For This Useful Post: |
01-05-2014, 12:18 | #2 (permalink) |
Freak Poster Join Date: May 2010 Location: INDIA
Member: 1302506 Status: Offline Sonork: india Thanks Meter: 14 | fir bhee na ho to contect me [email protected] |
