Old 07-20-2012, 17:59   #1 (permalink)
Member: 1420214
Thanks Meter: 33
how to removed nokia e7 user code?
i have atf,mx,hwk
Old 07-20-2012, 18:07   #2 (permalink)
.::ZUBER::.'s Avatar
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
Bro. Click Buscheck & Phone will appears in Local Mode, Go to Service Tab>IMEI & Security>User Code>Click Read will see your User Code. Put manually Code to Phone & will Unlock without Deleting any Data.
Other option is to Flash it with same Product Code latest Firmware & will appear in Local Mode, now Click Full Factory Reset will remove your User Code.
BR,
Zuber
The Following User Says Thank You to .::ZUBER::. For This Useful Post:
Old 07-20-2012, 18:42   #3 (permalink)
anujc143's Avatar
Member: 1550704
Sonork: 100.1644808
Thanks Meter: 248
no local mode flash the new flash file..............
Old 07-20-2012, 19:41   #4 (permalink)
$ktelecom's Avatar
Member: 484060
Sonork: 100.1596821
Thanks Meter: 406
Flash for atf box use latest ver
Old 07-20-2012, 21:00   #5 (permalink)
raselopu's Avatar
Member: 485407
Sonork: 100.1580486
Thanks Meter: 183
BR,
Zuber
Do u think these phones shows code? (encrypted)
think well
Old 07-20-2012, 21:03   #6 (permalink)
gsm_new1's Avatar
Member: 1189306
Sonork: 100.1589231
Thanks Meter: 273
i have atf,mx,hwk
bro full flash ur set r only write the uda file.....
bro
Old 07-20-2012, 21:26   #7 (permalink)
Member: 262425
Sonork: 100.1617691
Thanks Meter: 1,264
think well
Bro. I already gave other option of Flashing in my above post, i know it must not possible to read encrypt code some time.
BR,
Zuber
Old 10-03-2012, 14:13   #8 (permalink)
kachman's Avatar
Member: 272581
Thanks Meter: 118
If I flash UDA file, do i lose messages and contacts?
Old 10-04-2012, 07:47   #9 (permalink)
Member: 269202
Thanks Meter: 281
Hi
yes
if you flash UDA then all user data erased
Old 10-04-2012, 19:31   #10 (permalink)
bhiret's Avatar
Member: 1295624
Thanks Meter: 152
bro you need fbus cable (+ - bsi) as battery and usb to get local mode or test mode then read code or factory settings is simple and tested
Old 10-04-2012, 19:38   #11 (permalink)
Member: 344846
only with 4.7k resis and the USB conecting with UB-USB FLASH
like the others BB5's
Page generated in 0.21499 seconds with 10 queries
