10-08-2012, 14:14 | #1 (permalink) |
No Life Poster Join Date: Mar 2006 Age: 41
Member: 247987 Status: Offline Sonork: 100.1609015 Thanks Meter: 542 | Nokia Asha 302 RM-813 Successfully Flashed By MxBox Using device: USB ROM and HTI, FW ver: 00.50, SN: 01006630 Connection status: EHCI:HUB::USB 2.00 (High-speed) Driver: NMWCD, ver: 7.1.32.75 Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012) Processing MCU file: rm813__14.53.mcusw [BB5,XSR 1.6] size: 31.85 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Make sure USB cable, Battery and charger are removed from device. Insert USB cable, Battery back to device(make sure to have fully charged battery). Insert Charger or Press phone's power button(if flashing doesnt start automatically) Waiting for USB ROM device ... CMT SYSTEM ASIC ID: 000000030000022600010007400C192103032108 [RAPUYAMA ver: 3.x] CMT EM0 ID: 00001051 CMT EM1 ID: 00001060 CMT PUBLIC ID: A8680000FFFB7C401584DE0BD81CFF3E125054E3 CMT ASIC MODE ID: 00 CMT ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 CMT ROM ID: 2CAC45E23BC33C8B Loading CMT secondary boot code SecondaryBoot: RAPUv21_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 eBB5ProtocolType: NEW Secondary boot loaded. Storage0: 0000 0000 - 0000 0000 type: RAM, asic:CMT Storage1: FFFF 0000 - 0000 0000 type: MMC, asic:CMT Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage3: 0000 0001 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT Storage4: 00EC 0040 - 0000 0241 [Samsung 2Gb DDP OneNAND,2 Gbits] type: FLASH,MuxOneNAND, asic:CMT Suggested algorithm: XSR 1.6 Loading CMT update server data Algorithm: RAPUv21_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66F5 Supported Ids: 0003192103002107, 000C192103002107, 0003192103012107, 000C192103012107, 000C192103022107, 0003192103022107, 400C192103022107, 4003192103022107, 000C192103032108, 0003192103032108, 400C192103032108, 4003192103032108, 0003192103042108, 000C192103042108 Update server code loaded. Waiting for USB device removal ...OK Waiting for USB device arrival ...OK Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1DB32C29 FUR: Adding Asic CMT as client OK. CMT PAPUBKEYS HASH: 05BDE0ECC36CDEAA016A0565CB6BAE0B1585232E Storing certificate [NPC, CCC, HWC, R&D] ...OK Partitioning.... Partitioning complete Erase size: 49.81 MB CMT FLASH,MuxOneNAND area [00040000-000403FF] CMT FLASH,MuxOneNAND area [000C0000-0013FFFF] CMT FLASH,MuxOneNAND area [00140000-004BFFFF] CMT FLASH,MuxOneNAND area [004C0000-0073FFFF] CMT FLASH,MuxOneNAND area [00740000-0147FFFF] CMT FLASH,MuxOneNAND area [00160000-0017FFFF] CMT FLASH,MuxOneNAND area [03200000-0387FFFF] CMT FLASH,MuxOneNAND area [0F080000-0F67FFFF] CMT FLASH,MuxOneNAND area [01480000-0243FFFF] CMT FLASH,MuxOneNAND area [02440000-025BFFFF] Formating partition ... Flash programming ... CMT KEYS block sent CMT PAPUBKEYS: 05BDE0EC [] sent CMT DSP0 block sent CMT MCUSW block sent CMT MCUSW1 block sent CMT GENIO_INIT block sent CMT ISA+DYNSW block sent CMT ADA block sent CMT PRIMAPP block sent CMT PASUBTOC block sent CMT RAP3NAND block sent CMT UPDAPP block sent CMT ISA+EXTDRV block sent Programming completed in 8.375 s Processing PPM file: rm813__14.53.ppm_mec [BB5,XSR 1.6] size: 6.80 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 12.25 MB CMT FLASH,MuxOneNAND area [025C0000-031FFFFF] Flash programming ... Programming completed in 1.797 s Processing CNT file: rm813__14.53.image_mec_059L167_010 [BB5,XSR 1.6] size: 25.03 MB Supported Ids: 0003192103002107, 000C192103002107, 0003192103022107, 000C192103022107, 000C192103032108, 400C192103022107, 4003192103022107, 400C192103032108, 4003192103032108, 400C192103042108, 4003192103042108 Erase size: 184.06 MB CMT FLASH,MuxOneNAND area [03880000-0F07FFFF] Formating partition ... Flash programming ... Programming completed in 5.671 s Total time for flashing process(boot+erase+write) was 28.141 s Waiting for USB device removal ...OK Waiting for USB device arrival ... Waiting for device boot up ... Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 18DD2E85 Verifying communication to device OK. Phone type: RM-813 (Nokia 302) SW version: V 14.53 20-03-12 RM-813 (c) Nokia Imei plain: 35244805208611-8 Product code: 059L374 Battery voltage: 3820 mV, current: 164 mA Language Pack: - not available. SLPA ver[4]: PA_SL3/PA_SIMLOC30 (15 digit NCK) warning: avoid SW Downgrade & manual erase to this phone ! Camera config: 01035602004006, ver: SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid WMDRM_PD seems to be valid SIMLOCK_TEST passed SECURITY_TEST passed Imei net: 352448052086118 Version: SIMLOCK SERVER Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK1: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK2: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK3: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK4: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK5: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK6: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN BLOCK7: 1=OPEN, 2=OPEN, 3=OPEN, 4=OPEN, 5=OPEN FULL FACTORY... OK USER DATA... OK LEAVE FACTORY... OK SERVICE CENTER... OK SOFTWARE UPGRADE... OK PRODUCTION TUNING... OK Reset User Code (to default:12345) ... OK Completed in 0.922 s |
The Following 2 Users Say Thank You to murtaza_nns For This Useful Post: |
10-08-2012, 16:51 | #2 (permalink) |
No Life Poster Join Date: Mar 2011 Location: NIGERIA
Member: 1540810 Status: Offline Sonork: 100.1627394 Thanks Meter: 161 | Post here another time http://forum.gsmhosting.com/vbb/f550...-mxkey-767051/ |
